Author Topic: Edition 30 P's Build thread! 365bhp  (Read 39594 times)
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
Re: Edition 30 P's Build thread!
« Reply #30 on: August 28, 2010, 06:53:30 pm »
nice, my itg runs fine with the maf, just make sure you don't over oil the filter as this can screw up the maf, this wouldn't happen just after starting though.
MK7 GTI - ARRIVING DECEMBER
Offline Edition_30_P
  • Edition 30 P
« Reply #31 on: August 28, 2010, 06:56:42 pm »
Ok. I thought it should be ok but, I've been told otherwise. On Tuesday I will check a ne MAF sensor and take it from there! If too much Oil was sprayed on (Which I don't think was  :confused:) How would i rectify this? How can I clean it?
MK5 Golf GTI Edition 30|APR Stage 2+|Milltek Non Res TBE Decat|ITG Intake| Forge Twintercooler|Autotech HPFP Internals|Forge DV|R8 Oil Cap|AP Coilovers|WALK Kit|ECS Dog Mount| THS Mounts|Eibach F&R Anti Roll Bars|Sachs Uprated Clutch
  • -Given: 64
  • -Receive: 48
« Reply #32 on: August 28, 2010, 08:25:33 pm »
I don't think it will be because of the oil as this would of took a while to work in to the maf maybe after a few weeks and not just after the first start up, I fecked my maf up on my mk4 gti from doing this.
  • Edition 30 P
« Reply #33 on: August 28, 2010, 09:35:32 pm »
So, would you guys recommend that I try changing the MAF and seeing what happens from there!? My mates at work said that could be a problem..... Hopefully it is jus that as I've run out of money for now so don't know when I could get my TBE, Intercooler or HPFP to get to Stage 2!?  :laugh:
  • Edition 30 P
« Reply #34 on: August 29, 2010, 11:37:12 am »
I've just been sitting here doing some research and thinking.... I was going to order the S3 Intercooler from work and use that but, I've also been looking into the Forge Twintake for a while! And, from what I can see the Forge gives better, rapid cooling!?.. I just would like to know what people's experience's or opinion's on the 2 is!? I was at first thinking to get both but, if i Just went with the Forge that should do the trick for Stage 2+ should'nt it!? I don't want to buy the S3 one then have to go and buy the Forge!
Cheers guys!!  :happy2:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #35 on: August 29, 2010, 11:43:41 am »
THS IC FTW
Over the top mod list ;o)
Offline vRSAlex
  • -Receive: 253
« Reply #36 on: August 29, 2010, 11:46:52 am »
Deffo get the THS.  I have a used one for sale too  :happy2:
Follow AKS tuning on Facebook
  • Edition 30 P
« Reply #37 on: August 29, 2010, 12:14:49 pm »
PM'd, BDMAlex!!  :happy2:
  • Edition 30 P
« Reply #38 on: August 29, 2010, 12:15:43 pm »
What's so different between the THS, Twintercooler and the S3 Cooler?
  • -Given: 243
  • -Receive: 154
« Reply #39 on: August 29, 2010, 12:53:14 pm »
THS is the max IC core you can squeze into the original location, app. same outer size as the much more expensive APR IC but with a bigger core. so better than S3, and no need for a front mounted IC
  • Edition 30 P
« Reply #40 on: August 29, 2010, 01:02:20 pm »
Cheers, D! Did you put one of these on your Car? I was reading the product review on the THS and seems a serious bit of kit!!!
  • -Given: 243
  • -Receive: 154
« Reply #41 on: August 29, 2010, 01:15:32 pm »
i have the APR  one, the THS wasn't on the marked when i did my build. still haven't found any info as to how much effect the endtank design has,  the THS has smaller endtanks but dunno what it does effectwise. Still both are the top dogs for the mk V platform  :happy2:
  • Edition 30 P
« Reply #42 on: August 29, 2010, 01:36:25 pm »
Very helpful! I just need an Exhaust in my life now!! Really wanted the APR RScC but, too expensive for me and, knowone wants to sell em after they've bought them!! So going for eithe Blueflame or Milltek!!
  • -Given: 243
  • -Receive: 154
« Reply #43 on: August 29, 2010, 01:50:16 pm »
you married?? the wifey might be worth a penny or two. then you can get the RSC, you won't regret the investment  :grin:
  • Edition 30 P
« Reply #44 on: August 29, 2010, 04:12:04 pm »
LMFAO!!! Danish, your a mad man! Still single.. may see if one of the bits on the sides are feeling generous  :grin:
