Author Topic: Wheel recommendation for track  (Read 10422 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: Wheel recommendation for track
« Reply #15 on: August 22, 2010, 09:46:41 am »
Well, if the B16 springs go on the OEM plates it would seem logical to me for them to have the same upper diameter as stock ! From what I see, there are several choices on the market like K-mac, H2sport and K-sport (these are made for their own coils but seem to also work with others). K-mac goes for about 500$ while H2sport are half that (i don't know why this big difference). TT lower arms in my country are about 750 Euro (1000$) including ball joints, bolts, bushings...  The 2 options :
1) Camber plates > will pull the upper part of the damper towards the interior of the car, creating more negative camber and more room for the wheel to go well under the fender/arch, especially if the wheel is much wider than stock. From what I've read the ride with those + coilovers is harsher than only coilovers
2) TT arms > will pull the lower part of the damper towards the exterior of the car, creating more negative camber and a wider track between the front wheels but will not help much with the wheel going under the fender/arch. The ride is same as with the OEm arms so these have an advantage on bad roads
Those said above represent my logic and may be innacurate. Can anyone comment on them ?
you have to take into account the cars roll center, i'm no expert, Jonny C may be able to ellaborate more on this, i recall him writing about this before somewhere inhere, but this is from the american forum:
 :smiley:
Over the top mod list ;o)
Offline fuscobal
  • -Receive: 27
« Reply #16 on: August 25, 2010, 03:14:36 pm »
Very good articles. Just found on youtube the video of a guy with an STI WR1 with 317HP/432NM and just 1330KG. The car surpassed just about every car at Hungaroring (including me and some M3, GT3 RS...) and made a lap time of 2'07" on Michelin Cup 24/64x18 slicks >
. The time is absolutely phenomenal for a street car considering that on the same day (09.08.2010), the fastest lap was made by a Leon WTCC > 2'05" !
24/64x18 is approx. equivalent to 245/40/18 !
« Last Edit: August 25, 2010, 03:16:48 pm by fuscobal »
Mk5 GTI 6MT - Revo stage 3
« Reply #17 on: August 25, 2010, 04:01:25 pm »
 :smiley:
....Do you have a link to that American forum thread, Jake?  :happy2:
  • -Given: 243
  • -Receive: 154
« Reply #18 on: August 25, 2010, 04:11:20 pm »
 :smiley:
i have looked, but so far without luck, i'll keep searching though RR  :smiley:
Offline Janner_Sy
  • -Receive: 113
« Reply #19 on: August 25, 2010, 04:14:41 pm »
Quote
that guy in the BMW at first is well and truly shocking behind the wheel.
Offline fuscobal
  • -Receive: 27
« Reply #20 on: August 29, 2010, 12:57:50 pm »
I looked again at R888 recommendations > http://www.toyomotorsport.eu/tiredetail.php?tireconcept_id=20&id=3 and I've seen now that a 7.5x17" (OEM rim) would take 235/45/17 at the limit. They say :
- permitted rims : 7.5" - 9"
- measuring rim : 8"
I don't know exactly what they mean by "measuring rim". Is this the recommended rim width ? Is there any risk in running a 235 on my 7.5" wide rim if the car is so heavy ? (1700kg)
If there's no problem, it would be the cheapest option as I only need the tires and don't have to buy rims as well !
« Reply #21 on: August 29, 2010, 03:48:39 pm »
I run my semi slick tyres which are 225 on a 7.5 rim with no problems, that includes a trip to the ring, so i think you would be fine with 235.  :happy2:
Offline fuscobal
  • -Receive: 27
« Reply #22 on: August 29, 2010, 04:43:27 pm »
That's what I want to know...if going from 225 to 235 would be a problem. I've also run 235 street tires on 7.5" on the street but that can't compare to track use ! If there's any chance of the tire failing or going off the rim, I'd stay with 225 !
« Reply #23 on: August 29, 2010, 04:50:00 pm »
Depending on how low slung your suspension is set up, wouldn't you have to possibly make some adjustments to stop 235 tyres rubbing?
« Reply #24 on: August 29, 2010, 10:45:09 pm »
Stick with the 225's on a 7.5 x 17 rim :happy2:
My Team dynamics Pro race 1.2's were 8" wide and on 225's and still looked very chunky on the alloy rim (see pic below). No danger of scrubbing and you can get on with the job at hand on track.
Offline fuscobal
  • -Receive: 27
« Reply #25 on: August 29, 2010, 11:31:28 pm »
I will stay with 225 then. My camber is currently lower than -1 wich is not that great. If I'll have the money, I will probably install the TT lower arms. Hurdy, in the pics it looks like you have a lot of negative camber. How did you get that much ?
« Reply #26 on: August 30, 2010, 10:17:41 am »
That may just be the fact that the car was parked on an angle at the time I took the pics. The car is lowered and running Bilstein PSS10's and that is all that could affect camber.
Offline fuscobal
  • -Receive: 27
« Reply #27 on: October 13, 2010, 06:47:31 pm »
I just had a terrific track day at hungaroring with the TT arms wich gave me -2.3 of negative camber and the 225/45/17 Kumho V70a. The improvement was of 11secs/lap wich is huge !!!
« Reply #28 on: October 14, 2010, 07:56:23 am »
Am i getting confused. I thought that the TT arms only give an extra 0.5 degree of camber.  :chicken: 2.3 sounds like the morego jobbies.
« Reply #29 on: October 14, 2010, 09:36:33 am »
....Perhaps his car starts off with -1.8 degrees and the TT arms add the 0.5 extra to give -2.3   :confused:
