Author Topic: Cruise Control  (Read 7613 times)
Offline 182_blue
  • -Receive: 54
Re: Cruise Control
« Reply #30 on: August 24, 2010, 08:16:13 pm »
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 521 D    HW: 5K0 953 569 A
   Component: LENKS.MODUL   009 0122
   Revision: FF010E35    Serial number: 20091201100602
   Coding: 1892040000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_SMLSNGVOLWS A01002
   ROD: EV_SMLSNGVOLWS_VW36.rod
   VCID: 2D5564F3CD79
I wasnt bothered about speccing Cruise as i knew how easy aftermarket was then i found 2010 + cars cant be upgraded at the moment  :ashamed:
Shaun I was all set to fit cruise to DaveB's Roc but once I had taken it all apart I was gobsmacked that VW had changed it totally??? The slip ring now contains all the steering wheel controller :confused: and the stalks are all one item.
There is no retro kit at the moment BUT I would say has you have DSG you may be lucky and have the right controller and all you will need is the right set of stalks,  If you have VCDS and can get the steering controller part number for me I can get you the right stalk part number...
Darren :happy2:
Offline mortygttdi
  • -Receive: 146
Re: Cruise Control
« Reply #31 on: August 24, 2010, 09:39:02 pm »
I'm fairly confident I could do a 2010 > CC but I'd need to have a car to practice on  :evilgrin:
Stu there alot different than normal golf there the same has the Q5's and most new audi's
Darren
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Cruise Control
« Reply #32 on: August 24, 2010, 10:06:29 pm »
Darren
Yeah I had read up on it this morning, doesn't look too difficult.  Seems there are two manufacturers of the controller and the fixings differ.
Stu...
Offline mortygttdi
  • -Receive: 146
Re: Cruise Control
« Reply #33 on: August 25, 2010, 03:21:43 am »
the job is easy its just the parts are very expensive, the controller is something like£270 then the stalks are another £150 but it possible the with Shaun having DSG on the roc R he might have the right controller to start with? Ill be having a look later today.
Darren
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Cruise Control
« Reply #34 on: August 25, 2010, 08:17:59 am »
5K0 953 569 A has been superseded by 5K0 953 569 G which doesn't list the 8T0 PR code for CC.
5K0 953 569 H is PR code 8T0
Stu...
Offline mortygttdi
  • -Receive: 146
Re: Cruise Control
« Reply #35 on: August 31, 2010, 02:42:59 am »
Sean it looks like the right stalks is 5K0 953 502C around £75 and the steering controller is 5K0 953 569H £150
Darren
Offline 182_blue
  • -Receive: 54
Re: Cruise Control
« Reply #36 on: August 31, 2010, 03:05:57 pm »
Darren
Wow, certainly not cheap !, especially if it doesn't work, VW did talk about bringing out a work around, I might wait to see if they do, although I'm not sure what they could do to make it cheaper other than bring out a stalk that works with the old controller !
