Author Topic: Help! Warning lights on!!!  (Read 1817 times)
« on: August 21, 2010, 11:16:18 am »
Hi guys. Went to wales. Driving back, the tyre pressure, abs and tps lights all came on.
stopped on the side of the road, turned off ignition, turned it back on and only the abs remained lit. Car seemed to drive fine and the brakes are working well as is the clutch.
Drove on slowly and all three lit up again whilst driving but doesn't seem constant. Twice now all lights cut out for five seconds and came back on again.
What should I do? 60 miles from home. Do I press on or call breakdown?
Re: Help! Warning lights on!!!
« Reply #1 on: August 21, 2010, 11:19:35 am »
There's also enough brake fluid in the reservoir.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #2 on: August 21, 2010, 12:11:35 pm »
Those lights normally come on when the battery is disconnected.
Try driving it a little more and the basic settings may be completed.
Stu...
« Reply #3 on: August 21, 2010, 12:30:55 pm »
Still hasn't turned off. Currently at services for a break.
Car has driven fine. Manual says abs/tcs are on the same system so if there's a fault with one, both will light up. Don't know why the tyre pressure light's on.
Car hasn't been touched mechanically for a few months. Drove down to Wales fine. Started off back fine too. Lights came on but there's no warning in the midline display. When I restart the car, they go off except abs which stays solid yellow. But after driving a few yards, the other two light up and stay solid yellow too. A couple of times, going around corners, they seemed to turn off but then turn back on again.
20 miles 30 mins and I'll be home and will do a vcds log.
Nasir
« Reply #4 on: August 21, 2010, 01:20:19 pm »
The tyre pressure monitor is linked to the systems uswel I think. It measures the rolling radius of the wheels and not the actual pressure in the tyre.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #5 on: August 21, 2010, 01:51:22 pm »
Hope you got back ok.
« Reply #6 on: August 21, 2010, 05:51:45 pm »
Car drove fine all the way back home. Obviously with the wet weather, I drove more slowly and carefully than usual. 60mph on the motorway.
Did a VCDS scan:
Quote
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 73E1890F6BDD
1 Fault Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
            003 - Mechanical Failure - Intermittent
Anyone know how easy it is to get the sensor replaced? Car's still under warranty but it means having to take it in to the dealers and with the work rota as it is at the moment, it's near-impossible to take the car into VW during working hours.
