Author Topic: bluetooth and RNS510?  (Read 3027 times)
Offline M1llh0use
« on: August 21, 2010, 12:30:35 pm »
just picked up the new (to us) GTI and having a bit of an issue working out how to pair the phone to the car. Reading the manual it seems that you need an extra unit for bluetooth.
How do i determine weather this is fitted or not?
Offline Moschops
  • -Given: 118
  • Edition 30 No 2275
Re: bluetooth and RNS510?
« Reply #1 on: August 21, 2010, 01:13:26 pm »
Hi,
To determine whether it's fitted or not, switch blue tooth on your phone, then sit in the car and all being well the car IIRC should pick up the mobile. If it doesn't it sounds like you may not have it fitted.
Were you told the car has blue tooth installed ? If so did they say what version Kufatec or similar? Mine has the Skoda version and it works well.
Does the car have Sat Nav too? If so press the phone button...yes it does as you say in the title doh...press the phone button and once blue tooth has connected it should pic up your phone book. :happy2:
« Last Edit: August 21, 2010, 06:10:47 pm by Moschops »
Cheers,
Wayne
Offline M1llh0use
« Reply #2 on: August 21, 2010, 05:20:50 pm »
balls.
advert said it was fitted. tried setting phone to discoverable and nothing found.
back to dealer to find out what's what...
  • -Receive: 291
« Reply #3 on: August 21, 2010, 06:05:19 pm »
It might be an aftermarket unit rather than a vw oem one.
Offline mortygttdi
  • -Receive: 146
« Reply #4 on: August 21, 2010, 10:37:03 pm »
try searching for BT with your phone then start the car, sometimes the bluetooth is set to visible for only a short time so you cannot just sit there with the ignition or the car started trying to find a connection.
Darren
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #5 on: August 21, 2010, 11:49:02 pm »
Just to clarify and confirm what Darren is saying, it is the car that remains discoverable so you need to search with the handset and not hope the car finds the handset.
Stu...
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #6 on: August 22, 2010, 09:24:15 am »
If there's a unit working in concert with the 510, when you press the 'phone' button on the head unit, the screen will change to something along the lines of 'no phone attached'.
If there's no unit the 'phone' button will mute the audio but the screen won't change.
Simples :happy2:
Offline M1llh0use
« Reply #7 on: August 22, 2010, 09:46:00 am »
Ok that solves it then, when you press phone it just mutes.
Cheers for the info!
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #8 on: August 22, 2010, 07:13:27 pm »
You're welcome. I heartily recommend getting one of those systems fitted though. It transforms the 510. Brilliant!
However, if the dealer stated one was already fitted, you have a good case for 'misrepresentation of goods'. Perhaps it will give you a good lever to use to get a nice discount on the dealer retro fitting one? :evilgrin:
« Last Edit: August 22, 2010, 07:16:11 pm by LouCyffer »
Offline M1llh0use
« Reply #9 on: August 23, 2010, 08:26:24 am »
that's the line i'll be taking when speaking to the dealer!
Offline M1llh0use
« Reply #10 on: August 23, 2010, 10:07:47 pm »
so dealer not interested in doing anything (can't really say i'm surprised, independant trader without any service operation)
Is it possible to retro fit an OEM bluetooth kit?
If so what do i need to enable a bluetooth connection to the headunit?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #11 on: August 23, 2010, 10:56:00 pm »
OEM retrofit is entirely possible.
I have a guide on my Octavia website (www.octavia-vrs.com) which albeit a little old now will give you a rough idea.  It uses similar parts.
Stu...
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #12 on: August 24, 2010, 06:57:04 am »
I have a retrofit OEM system and it's great. Our own SteveP supplied & fitted mine. Also  Stu & MortyGTTDi can do the same. Depends on where you are in the UK.
It's a good forum, this  :signLOL:
Offline M1llh0use
« Reply #13 on: August 24, 2010, 07:48:05 am »
hmmm
well out of my range of abilities at the moment (recently broke both wrists)
what sort of cost was it to be fitted?
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #14 on: August 24, 2010, 06:52:10 pm »
I paid £240 fitted. Hope the #wrists get better soon :surprised:
