September 23, 2024, 02:23:25 pm
All Things Mk5
Mk5 General Area
wheel bolts
Topic: wheel bolts (Read 1093 times)
MR02LOW
Won't Shut up.
-Given: 8
-Receive: 14
My Ride:
wheel bolts
August 23, 2010, 09:48:52 am »
Hi guys,
I need new wheels bolts due to a change in wheels, the stealer wanted £3.22 inc VAT each
but found them on ebay for £19 all in (lockers sepearte).
Will these be the correct?
http://cgi.ebay.co.uk/20-x-Alloy-Wheel-Bolts-VW-GOLF-MK5-PASSAT-BORA-BEETLE-/250491453445?pt=UK_Cars_Parts_Vehicles_Wheels_tyres_Trim_Nuts_ET
Thread 14x1.5mm
Length 52mm
Thread Length 28mm
Head 17mm
Cone/Seat 60 degrees
I did a search to make sure i wanst re posting but cant find anything.
Help appreciated
Poppa Dom
Just look at my post count
-Given: 7
-Receive: 40
Re: wheel bolts
Reply #1 on:
August 23, 2010, 09:50:47 am »
Length of the bolt you need depends on the wheel you are fitting, some after market wheels need you to run slightly longer tuner bolts than the standard bolts. All other details you have put are correct, just check the bolt length for the wheels you are fitting.
MR02LOW
Won't Shut up.
-Given: 8
-Receive: 14
My Ride:
Re: wheel bolts
Reply #2 on:
August 23, 2010, 10:08:36 am »
tbh on the bay there is a company doing KEI Racing bolts for £20 i think i will purchase those, KEI are a reputable company so there will be no problem.
wheels are standard VW but a bit special so i presume standard length will be fine. will make sure tho first.
thanks guys
CAPTAIN BRITAIN
Always Involved
-Given: 19
-Receive: 12
Re: wheel bolts
Reply #3 on:
August 23, 2010, 01:51:06 pm »
Quality wheel bolts i would have thought are a must, same with tyres, i don't skimp on either.
All Things Mk5
Mk5 General Area
wheel bolts
