Author Topic: red rim on front grill  (Read 1188 times)
Offline gti265
« on: August 24, 2010, 04:59:30 pm »
hello all
anyone no how to remove this or replace it with a white one :)
thanks for any help :)
tom
MK6 Golf R DSG 2012 - FOR SALE - £20,000 - pm for info
Offline BenR
Re: red rim on front grill
« Reply #1 on: August 24, 2010, 05:02:15 pm »
Take the whole grill off, do this by popping the bonnet and removing two torx screws, then two underneath number plate located in lower honeycomb grill facing up.
Once these are out the whole gril will lift out. Then simply remove red strip using a flat head screwdriver to push the red pins out  (from the back of the strip of course) be careful as the strip snaps very easily!!
Offline gti265
« Reply #2 on: August 24, 2010, 05:15:11 pm »
wicked does it leave a mark/flat area that looks like there should be somthing there?
tom
Offline matsu
  • -Given: 78
« Reply #3 on: August 24, 2010, 05:23:16 pm »
i think peeps have sprayed theirs white or covered in white electrical tape and put back if that helps?
matsu
Offline gti265
« Reply #4 on: August 24, 2010, 05:28:47 pm »
ooo i mite give that a go tomrow if it ever stops raining :(
