Author Topic: MFD2 Questions????  (Read 3322 times)
Offline jaffa666
MFD2 Questions????
« on: August 25, 2010, 08:54:29 pm »
Hey troops maybe doing a px for an MFD2.
Just ahd a few questions, before I agreed to do anythin.
1st up, will this just be a simple case of plug and play, providing it comes with the code? or will it need coding to work in my car by a dealer or someone with vagcom.
2nd, I am aware this unit needs the disc for the Satnav to work, I have the 6disc changer in the arm rest, so could I just leave the nav disc in the unit and forget about it.  Also while using the nav could I play music from discs in the changer?
Any help on the above matters is much appreciated. cheers
Offline markfive
  • You ain't seen me, right?
Re: MFD2 Questions????
« Reply #1 on: August 25, 2010, 09:22:09 pm »
If memory serves it'll need coding (definitely if you have a Highline display), and yes you can use the nav and playback from the changer at the same time.
'57 DSG GTI alas now gone, but not forgotten....
Now motorway cruising in a 61 Mondeo Titanium X Sport 2.2 TDCi. 500+ miles to a tankful and bucketloads of torque :O Ok, it's not a GTI but it's fun... and that's what counts ;)
Offline jaffa666
« Reply #2 on: August 25, 2010, 09:59:46 pm »
Dont have a highline display so thats not an issue, so everything else should just be plug and play?
cheers for the info!!!  :happy2: :happy2:
Offline markfive
« Reply #3 on: August 25, 2010, 10:07:48 pm »
Nope, it does need coding even without a Highline - CAN gateway needs coding for navigation, and  MFD2 for sound system/no of speakers, phone preparation (if you have it) plus CD changer.
Other than that, it's plug and play  :signLOL: - the radio should work OK without coding........
And you'll need a GPS antenna. Retrofits often put these behind the dashboard, seems to work OK for most people.
Offline RagingKileak
« Reply #4 on: August 25, 2010, 10:10:26 pm »
What is a highline display anyway??
Guys, as I'm the 'proposer' of aforementioned PX - can anyone help me with this code thing?
Is it the security code? Should it be in the cars manual etc? I have a fair bit of documentation with the car but not sure what I'm looking for!!
Matt
Offline markfive
« Reply #5 on: August 25, 2010, 10:34:04 pm »
There's the security code that the buyer needs to activate the unit in their car - 4 digits, should be on a card, if not then you'll need to pay a visit to the service department of a VW dealer assuming the unit was factory-fitted (they will give you the code, FOC in my experience, if you quote the VIN or reg). You only ever need this code once when moving the unit from vehicle to vehicle.
VCDS (previously know as VAGCOM) coding is the term for the programming required to match the unit to the car and vice versa. Basically this is how you tell the car that the unit is installed and therefore that certain features should be activated or deactivated.
Offline jaffa666
« Reply #6 on: August 26, 2010, 09:03:32 am »
So it will need coding for the nav to work in my car then? Don't have a phone kit.
Can anyone with VCDS do it or will it be a trip to VW?
Sorry if these are silly questions but not got a clue when it comes to things like this.
Offline markfive
« Reply #7 on: August 26, 2010, 09:09:33 am »
Yes, it will need to be coded. Anyone with VCDS can do this, doesn't need to be a dealer. There is a list of forum members with VCDS here. If you can't find someone on here who is local, look for a VAG specialist garage, they will have the cable and know what to do. It's only a few minutes work.
« Last Edit: August 26, 2010, 09:13:31 am by markfive »
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #8 on: August 26, 2010, 04:13:20 pm »
Technically it may need coding, but it will work perfectly fine without.  Without coding some error messages will be stored but thats it.  Mine, and everyone else's was plug and play.
Sepang Blue S4 BE Avant
« Reply #9 on: August 26, 2010, 04:21:27 pm »
Handy to know, cheers mate.
Matt
Offline aidogti
« Reply #10 on: August 28, 2010, 08:50:59 am »
Mine was just plug and play, works fine, I put antenna on dash in the middle close to window screen.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #11 on: August 28, 2010, 10:18:57 am »
It really should be coded to match the car.  You can 'assume' your unit is plug and play because when you plugged it in it worked but that's not Plug and Play really is it.
You can get an idea of the coding from here - http://octavia-vrs.com/cms/content/mfd2-install-guide
There are also some details that might help if you have Aux In.
Stu...
Offline markfive
« Reply #12 on: August 28, 2010, 08:45:49 pm »
Indeed....
Nonwithstanding the audio side, I would also hazard a guess that if the CAN gateway isn't told to enable controller 37 then when the GPS lock is lost (in tunnels or whatever) the nav will lose position as there is no data from the ABS sensors?
