Author Topic: Think my fan has gone for ****, need help please chaps?  (Read 2446 times)
Offline Sunglasses Ron
« on: August 26, 2010, 11:55:46 am »
Now chaps.. Over the last few months I can honestly say that I have never heard my engine fan come on once  :confused: It was only after a fairly spirited drive the other day with a few mates (no videos, sorry  :signLOL:) when we was all chatting afterwards near our cars and my mate's S3's fan was blowing and mine wasn't. It then got me thinking that I couldn't honestly remember the last time I heard it  :confused:
Now I have had no warning lights come on and it's been on VAGCOM a few times recently (not in the last month though) and again no warning codes flashed up, but not sure if it would anyway. Are the fans on the GTI ridiculously quiet, or should I get mine inspected pronto (especially with the mods and standard cooler  :scared:).
What's your thoughts?
« Last Edit: August 26, 2010, 11:57:18 am by Sunglasses Ron »
Re: Think my fan has gone for ****, need help please chaps?
« Reply #1 on: August 26, 2010, 12:01:09 pm »
easy test start the car and leave it running and after a few min the fan should come on,just open the bonnet to see if it comes on
« Reply #2 on: August 26, 2010, 12:06:36 pm »
Pretty sure it doesn't Matt, but i'll check in a min. Will it still do it from cold though?
« Reply #3 on: August 26, 2010, 12:14:11 pm »
yes mate just open bonnet start car and after a few min it should come on
Offline FamilyDub
  • ...who needs a diesel?
« Reply #4 on: August 26, 2010, 12:14:48 pm »
There's two fans - a big one and a small one.
It's not unknown for the small fan to fail, leaving the car no choice but to activate the bigger fan.
MKV GTI | Reflex Silver | 5-dr, Family-Spec | 17" w/anthracite Finish | Manual | Highline | Cruise | Revision 'D' DV | Dirty Pipes |
Offline no golf clubs at all
« Reply #5 on: August 26, 2010, 12:18:48 pm »
Open the bonnet, you should be able to see them spin...try putting the ac on too (doesnt that make a difference)?
« Reply #6 on: August 26, 2010, 12:30:01 pm »
Will try this in a min. If they aren't working, what sort of affect will this have on the car (especially a modded one)?  :scared: Or is it just mainly for when the car is stationary?
Offline 94Luke
« Reply #7 on: August 26, 2010, 12:49:15 pm »
If the fan wasn't working I would have thought you'd be seeing higher engine temps on the gauge. fwiw on our car the fans are noisy as f*ck from the outside  :grin:
« Reply #8 on: August 26, 2010, 12:59:33 pm »
Been running ten mins with no sign of the fan..  :sad1: Off to VW I think..
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: August 26, 2010, 01:09:24 pm »
Off of the top of my head I can't remember where it is but pretty sure you can 'run' the fan with VCDS in 'output tests', much like you can cycle your electric windows or wipers etc.
http://www.ross-tech.com/vcds/tour/out_test.html
Stu...
Offline S2 Ant
  • -Receive: 21
« Reply #10 on: August 26, 2010, 01:10:53 pm »
Is the car over heating at all tho? Without the fan it would start to climb above 90 on the display in the car.
Its not overly warm out today and with the bonnet up the car might be able to lose enough heat without the fan kicking in, or at least take a bit longer to happen.
Leave it running with the bonnet down
Ant
« Reply #11 on: August 26, 2010, 02:21:41 pm »
Smaller fan should be running if you have the AC on in this weather.
« Reply #12 on: August 26, 2010, 07:41:21 pm »
Tried it with the aircon on earlier and both were spinning..  :pomppomp: But I still haven't seen/heard them going without the AC on..  :confused: Will keep an eye on them for a bit, but the temp gauge still stays at 90oC, so should be ok..
