Author Topic: MFSW Buttons  (Read 20153 times)
Offline otto-mate
    • Automated Home
Re: MFSW Buttons
« Reply #15 on: October 09, 2010, 05:09:14 pm »
Wooop...Woooop...scary airbag stuff?  Any pics or guides for this?
M.
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
Re: MFSW Buttons
« Reply #16 on: October 09, 2010, 05:14:28 pm »
Removing the Airbag
Drop the steering wheel all the way down and extend reach as much room as possible.
Turn the wheel one 1/4 turn to the right from straight ahead position
Now using a flat blade screwdriver unclip the airbag by placing the screwdriver into the hole on the back of the steering wheel and lever the spring catch in to the centre, Now turn the wheel 180° and repeat, the air bag will pop off. Horn may sound so best to disconnect battery.
The wiring comes from the flappy paddles and plugs into the blanking pieces that are on the steering wheel at the moment and from there the ribbon cable goes down to the controller, this does not require changing, just unplug the flappy paddles and remove the plug with the ribbon cable, remove torx screw  remove this part of steering wheel. Plug in the new buttons and then the flappy paddle wiring into the replacement buttons, it will all self explanatory when you remove the air bag.
Hope this helps, Steve  :happy2:
See link for a guide.
http://uk-mkivs.net/forums/t/156872.aspx
Offline otto-mate
    • Automated Home
Re: MFSW Buttons
« Reply #17 on: October 15, 2010, 11:57:09 am »
Many thanks Steve!
M.
Offline Gti182
  • Newbie
Re: MFSW Buttons
« Reply #18 on: July 10, 2021, 03:01:30 pm »
Hi All,
First post, recent mk5 gti owner.
Happened to come across this thread after installing MFSW buttons to my Mk5 Gti dsg (2007 South African spec).
I’m running RCD360 radio with the MFSW adapter wiring.
Everything felt like it connected well as far as I could tell but after connecting the battery none of the buttons work. I haven’t taken it for a drive other than a few meters out of the garage to reset the dash lights.
Does it need to do coding or reset anything? I have vcds but unsure where to troubleshoot now
Any help would be appreciated thanks
Offline Octoparrot
  • -Receive: 102
Re: MFSW Buttons
« Reply #19 on: July 11, 2021, 11:46:21 am »
Yes and you need to have the compatible steering control module fitted as well, as yours is a dsg it could be OK but being SA spec you can't be sure. Have you got the VCDS vag com diagnostic software?
Offline Jons1001
Re: MFSW Buttons
« Reply #20 on: July 11, 2021, 11:48:32 am »
I tried fitting these to my 08 dsg a few months ago. The buttons worked fine but once fitted my paddles wouldn't work! Had to take the buttons off in the end and the paddles started working again. If anyone had any ideas would be grateful to hear them.
Offline LC5F
  • -Receive: 80
Re: MFSW Buttons
« Reply #21 on: July 11, 2021, 12:01:55 pm »
Mine is a late 06 DSG -
I didn't install them by the book - too excited to get them, battery & air bag were still attached - but it did generate faults that cleared in VCDS.
IIRC the buttons just worked and no issues with paddles.
@Gti182 - just do an autoscan in VCDS and then go into each module to clear the faults
Offline Grevling89
Re: MFSW Buttons
« Reply #22 on: April 29, 2023, 10:30:30 pm »
Hey @LC5F!
Bumping this; I just installed MFSW buttons on my 07 GTI. I have Cruise Control, DSG and paddles already, but the buttons don't work. No faults, installed them by disconnecting battery and leaving airbag connected (although it was a pain to work around it dangling there haha).
Buttons light up but no buttons work. CC and paddles work perfectly so no difference in that sense.
What's your take - needs coding, or needs new control module?
Tagging others in case: @Octoparrot @Jons1001 @Gti182
2007 MK V - Pearl Black - 5 door - Happily stock
Offline kam760
  • On the search for an edition 30.
  • My Ride: On the search for one...
Re: MFSW Buttons
« Reply #23 on: April 29, 2023, 10:55:41 pm »
Genuine MSFW buttons? Lots of fake ones about
Offline Grevling89
Re: MFSW Buttons
« Reply #24 on: April 29, 2023, 11:20:52 pm »
Genuine ones! 100%.
Offline FarmaS
  • Newbie
  • My Ride: VW Golf MK5 GTi DSG 280HP
Re: MFSW Buttons
« Reply #25 on: August 11, 2023, 09:24:29 pm »
George
Offline Grevling89
Re: MFSW Buttons
« Reply #26 on: September 13, 2023, 09:41:42 pm »
Sadly, not gotten around to it yet. It's a bit of a hassle (as well as an expense) to hire a vagcom for a day to code it, and I haven't been scraping in money lately so it's on the backburner for now.
