Author Topic: Too much engine oil  (Read 2819 times)
Offline Lyons
  • -Given: 18
Too much engine oil
« on: August 28, 2010, 06:45:51 pm »
The oil light just came n saying check the level. It was just at the min so I topped it up about 1 litre.
Sadly I went too quickly and it's now about 3mm over the max, at the wrong end of the arrow!
Does this mean I need to drain done out? Does literally any amount extra mean bad news?
Offline Gti_Mad
Re: Too much engine oil
« Reply #1 on: August 28, 2010, 07:04:53 pm »
yes it does you can cause to much oil pressure causing it 2 blow oil seals and stuff
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #2 on: August 28, 2010, 07:29:12 pm »
For such a small amount over the maximum I wouldn't worry too much, it will soon burn it off.  What are you calling the maximum?  You are allowed over the hatched area if you look at the maintenance booklet in the handbook.
Sepang Blue S4 BE Avant
Offline Poppa Dom
« Reply #3 on: August 28, 2010, 07:39:36 pm »
3mm on the dipstick is not a small amount - I would suggest that you remove some of the oil as running the car with an excessive amount of oil can damage the cat.
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« Reply #4 on: August 29, 2010, 06:52:27 pm »
I wouldn't worry too much tbh. As long as its not over the second mark you should be fine :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #5 on: August 29, 2010, 07:10:22 pm »
I too would drain some off.
Better to be safe than sorry and have to replace blown seals :happy2:
