Author Topic: fuel pump leak  (Read 11014 times)
Offline edd666999
  • -Receive: 89
fuel pump leak
« on: September 02, 2010, 06:08:30 pm »
I decided to swap my cam follower today, took the right hand side metal connector off my fuel pump but realised I didn't have the correct M8 spline for the left side, so put the right side back on, put everything back together, opened my drivers door and the left un touched metal pipe started leaking fuel! I have tried tightening the bolts to no effect.
I'm going to get the correct M8 bit tomorrow and take it off, does anyone have any ideas why its pi**ing fuel!
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: fuel pump leak
« Reply #1 on: September 02, 2010, 08:02:46 pm »
Apart from something has come loose i can't think why.
Are you sure it's coming from there and not spraying from the one you did remove on to that one.
Re: fuel pump leak
« Reply #2 on: September 02, 2010, 08:04:44 pm »
Opening the driver's door primes the fuel pump hence the leakage.   :smiley:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: fuel pump leak
« Reply #3 on: September 02, 2010, 08:08:06 pm »
It shouldn't be leaking if it's all put back together. Which is what the OP did before opening the door.
Offline edd666999
  • -Receive: 89
Re: fuel pump leak
« Reply #4 on: September 02, 2010, 08:47:22 pm »
100% sure, it drips drips drips! it got worse when i tightened it!!!
i just hope that tomorrow when i get the correct bit that i can change the follower, put the pump back together and have no leak...otherwise...new screws? or pump possibly.
do you have access to that program that tells you the part numbers for the pump and all the metal connectors that go into the front of it?
i also fitted a new n75 valve as it was only £20 from dealers and took me 40mins to fit being very carefull.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: fuel pump leak
« Reply #5 on: September 02, 2010, 08:51:59 pm »
You mean ETKA
Yes give me 5 while i locate it…...
Offline gazbutS3
Re: fuel pump leak
« Reply #6 on: September 02, 2010, 08:56:21 pm »
have you crossed the thread of the union???
just a suggestion :smiley:
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
Re: fuel pump leak
« Reply #7 on: September 02, 2010, 08:58:09 pm »
Sounds like a real pig! My guess would be overtightening or you have cross threaded the connector.
Careful you don't bend the metal pipes too much when getting thebolt loose. The pipes need to be bent slightly though to remove the pump.
 The connections need to be nipped tight not overtight.
Hard to describe but you should be able to feel it.
Oh and don't be daft enough to drive it whilst leaking fuel :rolleye:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: fuel pump leak
« Reply #8 on: September 02, 2010, 08:58:17 pm »
What Engine code and model year are you? AXX 2006 isn't it?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: fuel pump leak
« Reply #9 on: September 02, 2010, 09:04:50 pm »
Does this help you?
Offline edd666999
  • -Receive: 89
Re: fuel pump leak
« Reply #10 on: September 02, 2010, 09:05:09 pm »
yea
Offline edd666999
  • -Receive: 89
Re: fuel pump leak
« Reply #11 on: September 02, 2010, 09:06:32 pm »
Does this help you?
from that picture i get the idea that that has 1 metal and 1 rubber pipe not the 2metal i have...
Offline edd666999
  • -Receive: 89
Re: fuel pump leak
« Reply #12 on: September 02, 2010, 09:07:38 pm »
it was real difficult to leave my car at my mates garage but i thought...do i was to be driving a flame ball on wheels?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: fuel pump leak
« Reply #13 on: September 02, 2010, 09:08:23 pm »
Hang on i'll get you the other pump then
Offline edd666999
  • -Receive: 89
Re: fuel pump leak
« Reply #14 on: September 02, 2010, 09:08:29 pm »
this is what im thinking...and by taking it off fully it will all work itsself out!
