Author Topic: fuel pump leak  (Read 11000 times)
Offline edd666999
  • -Receive: 89
Re: fuel pump leak
« Reply #15 on: September 02, 2010, 09:08:51 pm »
Hang on i'll get you the other pump then
:signLOL: thanks!
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: fuel pump leak
« Reply #16 on: September 02, 2010, 09:13:40 pm »
This is the only other Style pump listed for an AXX 2006 engine
Offline edd666999
  • -Receive: 89
Re: fuel pump leak
« Reply #17 on: September 02, 2010, 09:17:32 pm »
thats it! part 19 is the m8 thread, and 1b is the other bit.
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
Re: fuel pump leak
« Reply #18 on: September 02, 2010, 09:17:48 pm »
Thats it Carl :happy2:
Good choice to not drive it.
Had another thought to undo the splined bolt you dont have to touch the nut above it. If you tried to undo this it would just bind against the bolt and cause a leak.
Offline edd666999
  • -Receive: 89
Re: fuel pump leak
« Reply #19 on: September 03, 2010, 03:32:56 pm »
well i think its sorted....possibly.
no more leaks...from what i can see but does the fuel pump hiss? or is that some fuel escaping at very high pressure i can hear but cant see?
Offline edd666999
  • -Receive: 89
Re: fuel pump leak
« Reply #20 on: September 03, 2010, 07:03:19 pm »
bollocks.
just cleaned the left nut, and VERY slowly fuel seaps down it, never turns into a drip.....
vrs carl whats the part number for part 19?
cheers
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: fuel pump leak
« Reply #21 on: September 03, 2010, 07:34:46 pm »
2 Minutes turkish………
EDIT: Part no. is WHT 000 285 C listed as an M10X1 Banto Bolt - Will be about £4 :happy2:
« Last Edit: September 03, 2010, 07:40:26 pm by vRS Carl »
Offline edd666999
  • -Receive: 89
Re: fuel pump leak
« Reply #22 on: September 03, 2010, 07:40:22 pm »
Many thanks!
Offline edd666999
  • -Receive: 89
Re: fuel pump leak
« Reply #23 on: September 03, 2010, 08:43:03 pm »
Should there be any washers on those bolts?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: fuel pump leak
« Reply #24 on: September 03, 2010, 08:45:49 pm »
Not sure mate,
Not according to the Pic. I wouldn't think so but it would be best to check with a Stealer when you order a new one :happy2:
Offline bodger00
  • -Receive: 20
Re: fuel pump leak
« Reply #25 on: September 03, 2010, 09:23:26 pm »
There were no washers on mine......... :popcornsoda: :popcornsoda:
« Last Edit: September 07, 2010, 07:45:03 pm by bodger00 »
Offline edd666999
  • -Receive: 89
Re: fuel pump leak
« Reply #26 on: September 07, 2010, 02:15:53 pm »
Many thanks to all that replied, ended up with a new fuel pump and bolts. I couldn't fit the HPFP internals because I didn't have the correct tools, so just running standard fuel pump at mo, but to be honest I could take that pump off n back on in no time after doing it 10times already. Thanks to s2 ant for the pump and carl for part numbers!
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: fuel pump leak
« Reply #27 on: September 07, 2010, 03:38:39 pm »
Your welcome.
What tools are you missing as the only thing i didn't have was the deep socket. Soon got one though from local tool shop :happy2:
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
Re: fuel pump leak
« Reply #28 on: September 07, 2010, 05:18:55 pm »
when we done ours with vrSY from here we lost the washer inside the pump which caused a leak, what a ballache but we found it and all went back together fine in the end. its a tiny ting brass washer which makes all the difference
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
Offline edd666999
  • -Receive: 89
Re: fuel pump leak
« Reply #29 on: September 07, 2010, 08:31:59 pm »
Its the same tool you were missing!
