Author Topic: Idle problem - Now sorted :D  (Read 14118 times)
Offline keano
  • -Given: 79
« on: September 05, 2010, 08:19:48 pm »
Evening guys,
Today i took a long trip down to the Edition 38 show. When i parked up back at home i noticed the idle was fluctuating between about 1050 and 1200.
It has never done this before, although it was given a good thrashing today.
I've been out for a slow drive to try and reset the logic but it still idles funny.
I'm currently uploading a video. Any ideas? PLeaseeeeee help  :happy2:
EDIT:
« Last Edit: September 07, 2010, 06:52:49 pm by keano »
Nasir
Re: Idle problem - Please help.
« Reply #1 on: September 05, 2010, 08:58:18 pm »
It's like it's got a heartbeat   :signLOL:
Sorry I don't have a productive input
Offline WhiteGTI
  • F-A-S-T
« Reply #2 on: September 05, 2010, 09:04:09 pm »
Have you unplugged your MAF and then gone for a short drive to see if it idles/runs better?
2006 E46 BMW M3 - 343hp
Offline PDT
  • -Receive: 142
« Reply #3 on: September 05, 2010, 09:19:31 pm »
Find someone local and carry out a tb alignment.
(basic settings block 60)
Offline keano
  • -Given: 79
« Reply #4 on: September 05, 2010, 09:24:12 pm »
Hi
Just been for a run. I uplugged the MAF and it started gasping and fluctuating alot so plugged it back in.
It has no fault codes ( had a basic code reader)
However it does sound like there is a mini darth vader making a noise (almost like wheels screeching in the distance) when the boost comes on. - Split DV?
Saint Steve
« Reply #5 on: September 06, 2010, 09:14:58 am »
Sounds like a split diaphram of sorts, either maybe Dv or Pcv diaphragm gone.
Any sound of air leaks when you shut the engine off under the top engine cover?
Offline FamilyDub
  • ...who needs a diesel?
« Reply #6 on: September 06, 2010, 10:42:01 am »
Sorry to hear that, dude. :sad1:
Erratic idling, exactly like you describe, was what my car was doing before I had to have the PCV changed.
MKV GTI | Reflex Silver | 5-dr, Family-Spec | 17" w/anthracite Finish | Manual | Highline | Cruise | Revision 'D' DV | Dirty Pipes |
Offline keano
  • -Given: 79
« Reply #7 on: September 06, 2010, 03:11:30 pm »
Thanks everyone. I knew you'd come to the rescue.
How much is a split PVC valve to replace? Is it warrenty covered?
Saint Steve
« Reply #8 on: September 06, 2010, 03:12:26 pm »
Yes, just put car to stock (if mapped), pcv is around £35 to replace for the part.
Offline gulfstream11
« Reply #9 on: September 06, 2010, 03:59:07 pm »
You,ve just had it mapped have,nt you nick.. Did you get the switchable box?
Offline keano
  • -Given: 79
« Reply #10 on: September 06, 2010, 05:35:28 pm »
Sounds like a split DV to be honest guys. Never really noticed but its hesitating on boost.
Popping to statllers in sheffield tomorrow to have a new DV and have a look at the PCV.
Then on wednesday it's in for the cambelt tensioner. *squeek squeek squeek*
Thanks for all the replies.
I'll let you know how i get on  :happy2:
Offline keano
  • -Given: 79
« Reply #11 on: September 07, 2010, 06:29:31 pm »
UPDATE:
Problem solved.  :happy2: :happy2:
Great thanks to Statllers of Sheffield. Turned out to be a dodgy PCV valve that caused the idling problem and perhaps poor-ish-er (  :grin: ) running.
Also had the Revision D Divertor Valve fitted and it seems to pull muchhhhh harder. Even though my original was in perfect condition.
Ahh well.
 :drinking:
Saint Steve
Re: Idle problem - Now sorted :D
« Reply #12 on: September 07, 2010, 07:13:42 pm »
UPDATE:
Ahh well.
 :drinking:
 Good News   :happy2:
  • -Receive: 291
« Reply #13 on: September 07, 2010, 07:15:09 pm »
Nice to hear the problem got sorted out.
Offline Kiwi
« Reply #14 on: September 07, 2010, 08:11:17 pm »
Great result, nothing like a happy ending to a problem  :drinking:
