Author Topic: Eibach springs question  (Read 1460 times)
Offline aidogti
« on: September 08, 2010, 12:15:02 pm »
Hi lads, do any of you'd know if eibach shoreline springs from a Leon will fit a golf Gti wit dsg without any probs?
Have any of you's done it before?
The springs are for the cupra.
Offline vRSAlex
  • -Receive: 253
Re: Eibach springs question
« Reply #1 on: September 08, 2010, 12:58:48 pm »
If its the sportline kit you mean then the springs are the same and will fit fine.
Follow AKS tuning on Facebook
Offline aidogti
« Reply #2 on: September 08, 2010, 01:07:18 pm »
Oh yeah I meant sportline,  :wink:
Thanks for the reply.
Will it make a difference mine being dsg?
Will the drop be different?
Offline PDT
  • -Receive: 142
« Reply #3 on: September 08, 2010, 01:20:55 pm »
In My catalogue the DSG is listed as a different spring rate (higher poundage)
Offline aidogti
« Reply #4 on: September 08, 2010, 01:52:57 pm »
PDT will that cause problems fitting springs to a dsg that are for manual?
Offline PDT
  • -Receive: 142
« Reply #5 on: September 08, 2010, 02:47:03 pm »
front will sit a bit lower as the srings coils will be compressed a bit more, ride may feel a bit soft also. might dive a little to much when cornering.
get the right springs  :wink:
Offline aidogti
« Reply #6 on: September 08, 2010, 03:47:05 pm »
Ok will do PDT,
Thanks for the replies lads.
Offline vRSAlex
  • -Receive: 253
« Reply #7 on: September 08, 2010, 04:51:31 pm »
My Eibach Book Says:
Leon Cupra (1P) - Kit number E20-81-009-02-22 - Front springs - F21-15-007-02-VA - Rear Springs - F21-85-014-01-HA
VW Golf MK5 GTi DSG - Kit number E20-85-014-02-22 - Front springs - F21-15-007-02-VA - Rear Springs - F21-85-014-01-HA
So the kit numbers are different, but the springs that are in the boxes are the same between both kits.
Both cars have the same front and rear loads.
Offline aidogti
« Reply #8 on: September 08, 2010, 10:01:23 pm »
thanks BDMAlex i decided to buy them.. hopefully they go on without any problems
Offline PDT
  • -Receive: 142
« Reply #9 on: September 09, 2010, 09:47:35 am »
My catalogue has different kit numbers and different spring part numbers as well as a note to check vehicle weights before ordering.
