Author Topic: Hella Daytime Running Light LED's....  (Read 123221 times)
Re: Daytime Running Light LED's....
« Reply #90 on: February 17, 2010, 02:33:19 pm »
Dont try and kid him Robin, that day was pea-soup.   :fighting2:
« Reply #91 on: February 17, 2010, 03:09:21 pm »
 :signLOL:
Your right it was a bit foggy over Bills Mothers!  :grin:
Offline gazbutS3
« Reply #92 on: February 17, 2010, 03:13:10 pm »
seems ages ago that meet :smiley:
« Reply #93 on: February 18, 2010, 06:32:22 pm »
so when we doing the next one ? how many of those cars are still owned by the same people  :rolleye: a few of em have moved on and others have moved down in cars (mr P )  :P so we defo should do it again
« Reply #94 on: February 18, 2010, 10:02:30 pm »
Meet in the same place?
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
« Reply #95 on: May 04, 2010, 02:13:22 pm »
RR, how feasible with x amount of work is it to enable the full beam DRL like some Audi models (A6/A3's) on Mk5's?
If I need to purchase extra CANBUS modules, I don't mind a bit of work involved if an end result is achievable. This for me would be something I'd like because I'm limited as I don't have factory Xenons (North US DRLs are a no go).
'High' beams are never used for DRLs.  But in a Mk5 Golf, either the dipped beams or the front fogs can legally be set up for DRLs - it is just a simple couple of tweaks in VCDS.
  • -Given: 88
  • -Receive: 95
« Reply #96 on: May 04, 2010, 02:18:34 pm »
RR, evening sir.
Not the dedicated DRL strips. Like you, I'm not a big fan of butchering the panels and wiring to make them fit in properly. I also don't really want that look.
Like the Audi A3 8P's and latest but one gen A6, they use the full beam bulbs (at least I think so) as DRL's which I like. The S3 8P also has it, like gazbut's and JonnyC's iirc?
They are not 'full beam' bulbs at all.  Modern Audis no longer have a traditional separate halogen main beam (like our Mk5 Golfs) - the 'bulb' you are referring to on the Audis is just a dedicated DRL - on the A3 and B7 A4 range, they are just a P21W tungsten filament bulb, and on the D3 A8, are a clover leaf array of 5 LEDs (can't remember what the A6).
  • -Given: 88
  • -Receive: 95
« Reply #97 on: May 04, 2010, 02:21:09 pm »
Pete,
There's a thread on Tyresmoke all about what I think you may be after:
Linky : - How To Fit LED's RS4 B7 DRLs....
HTH. Otherwise check out the Audi forums, cos I don't know the answer  :happy2:
Thanks RR.
That fella on the link has replaced his yellow beams with a Xenon/white look beam.
I simply want to the use the full beams as DRL's with the bulbs I've already got, just like the Rs4 and other Audis with the same feature (I'm right in saying they are the full beam bulbs aren't I?)
I think what I'm referring to is the high-beam or 'Hi-Beam' DRL.
I don't think it can be done as I've checked all the VAGCOM modules, but obviously purchasing an upgraded module might do the trick, but I don't know anything about what's involved with that hence my question  :smiley:
To use the H7 halogen main beam on the Mk5 Golf as a DRL would be fairly dangerous - which is why it can't be enabled in VCDS.  Dipped beam or fog lamps remain the only factory fit OEM DRL option.
  • -Given: 88
  • -Receive: 95
« Reply #98 on: May 04, 2010, 02:24:05 pm »
I'm gonna try and bring this one alive again if I can as I'd love to know the answer, I'm determined :wink:
What I meant by the previous few posts was I want to wire my GTI so that the full beams are on in the day, on their own. Even if they have to be triggered by a switch or something, that's fine. I just want to achieve the look of the 8P S3 and Mk6 Golf range with (at least what I think) is the 'Flash to pass' (in US Terms) or high beam/full beam (in UK terms) as an independent light. Obviously currently, I can only use Hi beam/full beam with the headlamps on dipped beam. Pulling the stalk towards the hi beam position without dipped beam invoked does nothing.
If it's possible to wire them in this fashion, I can then run them in the daytime in place of a DRL.  :smiley:
Hopefully, I'm coming over slightly clearer in my question :innocent:
Not only will you severly dazzle oncomming traffic, but you will no doubt get pulled by the plod if you drove around with your main beams on permanently.  :mad:
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #99 on: May 04, 2010, 05:46:32 pm »
Pete,
Thanks RR.
Thanks for the response TT, this is an old one now and I've learnt a lot since these posts about the bulbs and how they are used.
When you refer to dipped beam, do you mean simply the headlight 'on' position? I assume you do.
Indeed, that makes sense however you can see why I thought they were the H7 full beam bulbs, purely because A; they are positioned in the regular location (on most VWs and Audis) where the full beam bulbs usually sit and B; they are much brighter than regular W5 sidelight bulbs thus I guessed that these would be about the same brightness as a H7 bulb in some shape or form, but seems not to be the case judging but your explanation  :smiley:
Cheers.
Pete
  • -Given: 88
  • -Receive: 95
« Reply #100 on: May 04, 2010, 06:25:09 pm »
Pete,
Thanks RR.
If DRLs are enabled in VCDS (I think this is the 'Scandanavian' setting), then dipped headlamps will be on whenever the ignition is on - with regards to the actual headlamp switch, this basically becomes useless - because the Scandanavian DRL setting effectively disables using side lights (apart from on a stationary parked vehicle - which is all they are good for anyway).  If you use the North American DRL setting, you can then sub-select either the front fogs OR the dipped headlamps as DRLs, and this setting also retains control of the headlamp switch (I think) meaning you can still turn off the 'DRLs' and drive on 'city lights'.
Cheers.
No worries mate.  I fully understand where you come from on this.  Indeed, on my RS4, I actually wish there was a way of making the DRLs illuminate with full beam - because to onlookers, the Bi-Xenons tend to look f.ing bright on dipped as well as main - and a 'retaliatory' main beam flash sometimes doesn't get through their thick skulls that my dipped Xenons are not too 'high'.
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #101 on: June 11, 2010, 08:11:48 pm »
Sean/Robin,
Which MY or model came with the P21W DRLs in the A3/S3 range if you know at all please?  :smiley:
Thanks.
Pete
« Reply #102 on: June 11, 2010, 08:49:08 pm »
Sean/Robin,
Thanks.
....Sorry, Pete - I have absolutely no idea about Audi's.
  • -Given: 88
  • -Receive: 95
« Reply #103 on: September 01, 2010, 02:17:12 pm »
Just a bump to remind me to look up later!  :ashamed:
« Reply #104 on: September 01, 2010, 02:19:31 pm »
....Oh dear! Here comes a lot of reading and writing for me!  :laugh: :wink:
