Author Topic: headlight problem  (Read 1295 times)
Offline niallo
headlight problem
« on: September 09, 2010, 08:21:24 pm »
just been driving with my headlights on for first time since winter and after 15 minutes of driving a front right dipped beam fault has came up and the right main headlight is not on. is it as simple as a faulty bulb . any ideas what this fault might be?
cheers niall
Offline Weston
Re: headlight problem
« Reply #1 on: September 09, 2010, 10:41:23 pm »
cheers niall
Most likely just a blown lamp. Buy some new ones and upgrade to something good like osram nightbreakers. To check quickly, swap a bulb from the other headlight and see if it works.
GTI going...
  • -Receive: 291
« Reply #2 on: September 10, 2010, 01:21:04 am »
Yep. Mine did the same. I had the uprated Philips powerbulbs and the right dipped one blew. Swapped it temporarily with the right main until i could replace it.
Offline niallo
« Reply #3 on: September 10, 2010, 07:41:00 am »
cheers for the help lads greatly appreciated  :happy2:
Offline Weston
« Reply #4 on: September 10, 2010, 07:01:06 pm »
If you want osram nightbreakers I have some for sale. Let me know if you're interested, I'm cheaper than looking online  :happy2:
GTI going...
