Author Topic: Kenwood ignition issue  (Read 1175 times)
Offline Lyons
  • -Given: 18
« on: September 09, 2010, 09:21:44 pm »
Just tried fitting a kenwood DDX unit but it wouldn't switch on/off using the key, just via the power button at the front.
Before anyone suggests it, yes I did try swapping the red and yellow wires!!! But to no avail.
I have a Parrot ck3100 fitted too, so I even tried it with the Parrot loom removed, but made no difference.
Anyone any ideas? So close yet so far!
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Kenwood ignition issue
« Reply #1 on: September 09, 2010, 09:41:15 pm »
The VW doesn't have a switched ignition live at the quadlock.  That's your problem.
The OEM units are switched on and off using CAN commands.
Stu...
Offline Lyons
  • -Given: 18
« Reply #2 on: September 09, 2010, 10:01:20 pm »
So I read.
I think I'll have to tap into the fusebox feed for the parrot and connect it to the red ignition on the HU loom.
