Author Topic: mk5 gti problems..  (Read 4678 times)
Offline cs01uk
mk5 gti problems..
« on: September 09, 2010, 11:23:23 pm »
Bought an 07 mk 5 about 3 months ago since owning the vehicle i have had a remap. Just before havin this done it started to cut out at junctions whilst on tick over.. I had the re map done an everythin was fine but would still cut out once or twice whilst at a junction. Since then it has started to get worse! It cuts out more regulaly but only on tickover also seems a little under power and splutters when pulling away...
Had it plugged in to a diagnostics computer and no faults where shown!
Any help????
Also fitted a forge blow off valve which has started to hiss on low revs as if its losing pressure..
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: mk5 gti problems..
« Reply #1 on: September 09, 2010, 11:26:39 pm »
Some things that affect idle are PCV and Oil Filler Cap.
Try removing the Forge valve and refitting the OEM one.
Stu...
Offline SeanyK
  • -Given: 35
« Reply #2 on: September 09, 2010, 11:50:24 pm »
Absolutely as above - Take that DV off and put the OEM one back on, it's surprising how many problems can be caused by the DV itself.
Offline gazbutS3
« Reply #3 on: September 10, 2010, 07:01:07 am »
as VRStu said, alot of tickover issues are down to a leaky PCV
Offline cs01uk
« Reply #4 on: September 10, 2010, 12:58:32 pm »
ok thanks for advice i'll giv that a go.. any idea what part number i need for replacement OEM one obviously i need to upgrade it becausde i hav had a remap..
Offline cs01uk
« Reply #5 on: September 10, 2010, 06:53:31 pm »
Would it be the revision D that i need?
Offline SeanyK
  • -Given: 35
« Reply #6 on: September 10, 2010, 06:59:09 pm »
DV Part number is 06H 145 710 D
Thats the revision D :)
