Author Topic: Boot Open Button on Keyfob  (Read 8279 times)
Offline .:GTI|SUNNY:.
  • I spend too much time on this forum, I'm addicted
« on: September 14, 2010, 11:56:48 am »
Hi All,
I've only just realised that on both my keys the 'Boot Open Button' doesnt do anything
NOW
when i had my R32 i cant remember if it was the same with them keyfobs but i did have something done via VAG.COM which enabled the boot to pass it's 2nd lock
So do i need to do the same on the GTI or are my keyfobs knackered and need to have new ones from VW?
any help appreciated
Sunny
| Tornado Red GTI |
Offline edd666999
  • -Receive: 89
Re: Boot Open Button on Keyfob
« Reply #1 on: September 14, 2010, 12:00:26 pm »
when you press and hold the boot button, the boot doesn't unlock? it still requires you to use the badge to open the boot.
If you want the boot to "pop" open then yes you will need vagcom
Offline CAPTAIN BRITAIN
« Reply #2 on: September 14, 2010, 12:40:57 pm »
I've been led to believe that you need some skoda and scirocco parts to do the boot pop mod,
Didn't know it can be done with just the button alone.
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #3 on: September 14, 2010, 12:43:15 pm »
You need to hold the button down for a good 3 seconds or thereabouts and the indicators should flash to signal you can open the boot.  Are you sure you are holding it down long enough?  You wouldn't be the first not to (me included) ...
Sepang Blue S4 BE Avant
« Reply #4 on: September 14, 2010, 02:34:55 pm »
thanks for the replies,
i've just been out and tried, as above before i wasnt holding the button for 3secs but now i've just tried and it unlocked and the lights flashed  :smiley:
but now i want it to pop open like my R32 did, anyone know if VW will be able to do it for me?
| Tornado Red GTI |
Offline edd666999
  • -Receive: 89
« Reply #5 on: September 14, 2010, 02:36:39 pm »
to make to boot full open yes you need other parts, but as far as im aware you can make the boot pop open enough (an inch) so you can pull the boot open yourself rather and using the badge.
« Reply #6 on: September 14, 2010, 02:55:25 pm »
thats correct i had this  :smiley:
| Tornado Red GTI |
Offline damoegan
« Reply #7 on: September 14, 2010, 03:14:07 pm »
How is this done? any guides for doingit?
Offline edd666999
  • -Receive: 89
« Reply #8 on: September 14, 2010, 03:16:25 pm »
its done using vcds.
you can also achieve:
with a few parts
and:
http://www.ecstuning.com/stage/edoc/MK5RearHatchPop.pdf
Offline MattPoss
« Reply #9 on: September 15, 2010, 06:24:50 pm »
Ive seen the boot pop open fully using a valve spring out of a Transit van engine in the gas strut.
Think it could have been on a guy called NotNormal's car, will have a ratch about.......
Matt
Offline MattPoss
« Reply #10 on: September 15, 2010, 07:50:38 pm »
Here you go, here's his how to on uk-mkivs.net.............
http://uk-mkivs.net/forums/t/222365.aspx?PageIndex=3
Look at his post from January the 1st 2009. If you scroll further through you will see a link to someone elses 'How To' :happy2:
Matt
« Last Edit: September 15, 2010, 08:02:01 pm by MattPoss »
Offline damoegan
