Author Topic: RCD510  (Read 3450 times)
Offline Dan
RCD510
« on: September 15, 2010, 02:11:25 pm »
What is the biggest SD card you can use in the RCD510?
Dan
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: RCD510
« Reply #1 on: September 15, 2010, 02:39:58 pm »
depends on your firmware
1100 or below 2Gb SD card format
1200 and up 32GB SDHC card format
Offline Dan
Re: RCD510
« Reply #2 on: September 15, 2010, 02:47:00 pm »
How do you find out with firmware it has?
Dan
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: RCD510
« Reply #3 on: September 15, 2010, 02:51:43 pm »
you need to have the secret menu activated, which is bought up by holding down setup, which will show you the radio setup menu and then if the button is held longer will enter full setup mode and you can then find the software and hardware versions.
But you may need VCDS to activate this function.
Offline Dan
Re: RCD510
« Reply #4 on: September 15, 2010, 03:09:17 pm »
Thanks for that.
Is there a cross over date of when the 1200 firmware was used from?
Dan
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: RCD510
« Reply #5 on: September 15, 2010, 04:44:05 pm »
I have no idea of the firmware and model years, actually just noticed this is RCD which have different firmware versions.  and looking at the my-gti link the rcd510 has always supported sdhc so looks like you will be good upto 32gb card.
Sorry for the confusion, I just saw 510 and and missed the C.
my-gti
Offline Dan
Re: RCD510
« Reply #6 on: September 15, 2010, 05:33:55 pm »
Thanks for that!
Looks like I can use an sdhc card instead of buying an mdi unit.
Dan
