Author Topic: Need a new rear VW badge, advise needed!  (Read 21250 times)
Offline dajonic
  • -Given: 17
Re: Need a new rear VW badge, advise needed!
« Reply #15 on: September 18, 2010, 12:49:16 am »
I'm bidding on the second one
Offline big al
« Reply #16 on: September 18, 2010, 05:49:03 pm »
In that case, so am I  :evilgrin: :evilgrin: :evilgrin: :evilgrin:
I replaced my 05 badge with a newer one, and think it looks much nicer now. What is the difference between the later MK5 ones, and the Mk6 one?
Offline dajonic
  • -Given: 17
« Reply #17 on: September 19, 2010, 01:39:35 am »
^^^ :fighting:
Offline Matthew.
« Reply #18 on: September 19, 2010, 05:13:55 pm »
Does anyone have a link to a guide for removing the rear boot-badge handle assembly?
I'm wanting to remove it so I can fit a Mk4 Chrome badge to the assembly due to the corrosion  :smiley:
Edit* Just found one! lol  :happy2:
« Last Edit: September 19, 2010, 05:57:21 pm by matt8586 »
2006 Golf GTI - Diamond Black Pearl - Edition 30 Pescaras - Armrest - CD Multi-changer - Colour Coded Rear Valance
Progress thread - http://www.mk5golfgti.co.uk/forum/index.php/topic,65230.new.html#new
Offline dajonic
  • -Given: 17
« Reply #19 on: September 21, 2010, 09:51:34 pm »
Who else is bidding on that second badge?? Big Al??
« Reply #20 on: September 21, 2010, 10:13:48 pm »
here is a guide that Hurdy sent me when i did mine
Now all Japanese!
   Boot latch
« Sent to: maxitrol on: July 14, 2009, 04:09:19 pm »
« You have forwarded or responded to this message. » Quote Reply Remove
Hi,
I changed mine recently and the hardest bit was lining up the trim to put it back on after the boot latch was fitted
Seriously though, it isn't hard at all and if I can do it anyone can. It took me just under an hour.
First off open the boot and you will see two screws in the hatch grab handles. Remove these.
There are two plastic trim parts that cover the bulb area at each side of the hatch trim, pull these and they will come off quite easily.
Now you need to be brave, put your hands around the two holes where you've just the trim covers and tug hard.....then realised you haven't tugged hard enough and tug harder until the trim pops off. There are around 10 to 12 metal clips holding the hatch trim in place, so it does REALLY need a hard tug. You may find that it is easier to pull off one side first.
Once the trim is off you will notice two things...
1. the latch mechanism is held by 3 torx screws
2. you can't get at them all for the rear windscreen motor!!!!!
All you need to do is undo the screws holding the motor and rotate the whole assembly through 90 degrees - you don't have to take it off!
Once you've done this you will need to disconnect the latch mechanism electrically. It is simply a slot in/out connector. The connector has a little locking catch but all you need to do is depress this and it will slide out.
Now undo the 3 screws and remove the original latch.
Then as they say, fitting is the opposite of removal.
Hope this helps.
Offline big al
« Reply #21 on: September 21, 2010, 10:16:52 pm »
No mate, I was just winding you up, sorry, and good luck bidding.
Offline Matthew.
« Reply #22 on: September 21, 2010, 10:19:17 pm »
Thanks alot for that mate, really helpful, ile be attempting this at the weekend weather permitting
Matt
« Reply #23 on: September 21, 2010, 10:27:24 pm »
the hardest part i found was putting the rear panel back on correctly
Offline Matthew.
« Reply #24 on: September 21, 2010, 10:31:17 pm »
Nice one Andy, is the wiper motor a doddle to move then?
« Reply #25 on: September 22, 2010, 12:27:39 am »
i didn't take the whole moted off ..just undid the torx screws holding it in and moved it out of thw way to get the last one
Offline Matthew.
« Reply #26 on: September 22, 2010, 08:26:31 am »
Thanks Andy!
Offline markymark
« Reply #27 on: September 22, 2010, 09:14:16 am »
Brace yourself about £90!! :rolleye:
You can pick up a bargain occassionally on ebay, I just paid £28 for one!! :happy2:
Offline Matthew.
« Reply #28 on: September 22, 2010, 12:08:32 pm »
I can beat that mate, paid £1.20 for a Mk4 one I am going to adapt to fit lol. I love eBay sometimes!
Offline markymark
« Reply #29 on: September 22, 2010, 01:09:24 pm »
Nice one, I have a MK4 badge on the shelf in the garage, might try fudging that one to fit too! I bought a MK6 one for £28 which I thought was a bargain!
