Author Topic: Threaded bolt head removal....  (Read 2128 times)
Offline u01atc8
« on: September 19, 2010, 04:03:36 pm »
Ok so a little bit of help needed!
I tried to remove my back seats and the bolt for the larger back section seatbelt is threaded already do obviously someone has had a gonat one Yupik a time before I bought it.  So anyway how will I remove it! It's the one if your in th boot on the right hand side screwed into the bottom if the car. I was going to drill through it but was worried that I would hit the fuel tank or something! Then I would get fright!   :jumping:
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Threaded bolt head removal....
« Reply #1 on: September 19, 2010, 06:22:24 pm »
Brute force I would think, it's been screwed in wrongly so it'll normally come back out.  It'll probably not go back on without running a tap down it first.  Much better solution than drilling out if you can manage it.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #2 on: September 19, 2010, 06:24:20 pm »
Just had another thought -
These do pass through to the bottom of the car IIRC, so it may just be covered in sh*te under the car which is stopping it coming back through.  If you can locate the underside of it and soak a load of WD40 onto it that may help.
Stu...
Offline uk_stu
« Reply #3 on: September 22, 2010, 10:18:35 am »
http://shop.ebay.co.uk/?_from=R40&_trksid=p3907.m570.l1313&_nkw=easy+outs&_sacat=See-All-Categories
Drill a pilot hole then begin to wind the reverse thread easy out down it then hey presto!
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #4 on: September 22, 2010, 10:56:37 am »
Only really required if the head on the fixing is destroyed.
Stu...
Offline u01atc8
« Reply #5 on: September 28, 2010, 04:31:17 pm »
yes destroyed is the word! lol
