Author Topic: Secret menu via clima control  (Read 4726 times)
Offline monkeysquid
« on: September 19, 2010, 08:06:16 pm »
Hello,
Does any one know what all the codes/menus are if you press 'Econ' and the 'Air up' direction button on the climatic control panel?
Up to now i have figured if you turn the passenger knob to number 19 on the passenger display it gives you KPH/Oil temp etc in the drivers side panel.
Thank you!................
Offline ILoveTuna
Re: Secret menu via clima control
« Reply #1 on: September 19, 2010, 08:12:35 pm »
Too much time on your hands!!  :signLOL:
Offline Poppa Dom
« Reply #2 on: September 19, 2010, 08:18:14 pm »
VW Climatronic Readouts
1. Hold down "ECON", and press the "up-vent" button (next to recirculation). Both temperature displays will read 00 or 00'0, and you can release the buttons once they do.
2. Twist the LEFT temperature knob until the display above reads 19’0.
3. Twist the FAN knob until the left temperature display reads 19’1 (like 19.1).
4. The right temperature display is now a digital speedometer! HOW COOL IS THAT!!!
--- For tach (in x100), twist the FAN knob until the left temperature display reads 19’3 (like 19.3)
--- To reset and go back to normal operation, hit the ECON button once.
These are the different settings the Climatronic can display. The numbers on the left indicate the “CHANNEL” it MUST be SET to:
• 1.0: Temp as read by sensor in middle fan speed knob.
• 1.4: Light intensity falling on same sensor.
• 4.0: Outside Temp – front bumper
• 4.1: Outside Temp – roof.
• 4.2: Outside Temp – rear bumper (inside temp?)
• 15.0: Oil Temp
• 19.0: Uncorrected Speed (Km/h)
• 19.1: Uncorrected Speed (Mp/h)
• 19.2: Coolant Temp
• 19.3: Tachometer (x100rpm)
• 19.4: Oil Pressure
• 25.0: Voltage
Offline monkeysquid
« Reply #3 on: September 19, 2010, 08:26:21 pm »
Thanks DOMT, much appreciated!  :happy2:
