Author Topic: Airbag Fault After RNS-510 Install?  (Read 2508 times)
Offline R32 mad
« on: September 20, 2010, 02:24:57 pm »
I have just installed my RNS-510, as soon as I started the car an Airbag fault appeared in the dispay with a warning light?
Is the installation of the RNS-510 related?
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: Airbag Fault After RNS-510 Install?
« Reply #1 on: September 20, 2010, 02:31:15 pm »
Could be the airbag indicator on the central vent, if that got un-plugged and the ignition was on then you will need to clear the code, or it  could still be diss-connected?  otherwise it shouldnt be causing any issues.
Offline R32 mad
« Reply #2 on: September 20, 2010, 02:36:43 pm »
Airbag indicator? would this be visible when installing the RNS-510 when the centre dash has been dissembled?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #3 on: September 20, 2010, 03:07:17 pm »
Have you had the battery disconnected?
I can't see why you would need to disconnect the AirBag indicator on the central console to fit and MFD3 but it's worth checking to see if it has somehow been knocked.
If nothing looks amiss and you just had the battery disconnected the light should go away within 200m of driving the car.
Offline R32 mad
« Reply #4 on: September 20, 2010, 03:30:22 pm »
Battery was never disconnected, I suppose it's worth checking is the cables in the centre dash is still connected up properly. If not does this require the dealer to fix the fault? i.e. vagcom?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #5 on: September 20, 2010, 03:41:32 pm »
If you can find someone with VCDS they could clear the code for you.
If it is then a problem it will come back. At which point i would then be in to the dealer.
Offline vr6t
« Reply #6 on: October 06, 2010, 09:17:56 pm »
Mine did the same but i think it was part of recoding the new can gateway, i reset it with VAGCOM and it hasn't come back.
"A mk5 gti why did you buy that??" Quote of the week from trouble and strife...
Offline QD MBE
  • -Receive: 102
« Reply #7 on: October 06, 2010, 09:23:19 pm »
As said, airbag indicator centre dash.  Must have turned the Ignition on without it being connected (maybe to test the rns?).
