Author Topic: Alternatives to AG Tyre Foam  (Read 3030 times)
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« on: September 24, 2010, 09:35:07 am »
Hi guys, I was wondering if anyone could suggest any alternatives to AG Tyre Foam? Or will Bilberry suffice?
Re: Alternatives to AG Tyre Foam
« Reply #1 on: September 24, 2010, 09:48:31 am »
i use bilberrry juice..its amaming stuff
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #2 on: September 24, 2010, 10:15:19 am »
I get mine from these guys www.carchem.co.uk
« Reply #3 on: September 24, 2010, 02:26:46 pm »
Confused, you after tyre dressing or wheels cleaner?
  • -Given: 32
  • -Receive: 78
« Reply #4 on: September 24, 2010, 02:53:43 pm »
The tyre foam I was using was applied before any tyre dressing, so after cleaning the wheels with AG Clean Wheels I would spray it on and leave it while I washed the rest of the car, then I'd rinse it off before applying tyre dressing. It would basically remove any dirt and residue leaving a good clean surface to apply the dressing.
I'm using Bilberry and Chemical Guys New Trim Gel now, but can't find the AG Tyre Foam.
« Reply #5 on: September 24, 2010, 04:51:29 pm »
With you now!  :wink:
In that case I just spray either the Bilberry or some APC on the tyres and aggitate with a soft brush, that usually does the trick!  :happy2:
  • -Given: 32
  • -Receive: 78
« Reply #6 on: September 24, 2010, 04:59:57 pm »
Cool, cheers Nathan.
The wheels looks fantastic on the car by the way - desperately needs lowering though, looks like it's on stilts!
Offline keith
« Reply #7 on: September 24, 2010, 05:40:14 pm »
I have a couple of tyre foams - Armoral and Autosmarts tyre dandy these are along the same line as AG tyre foam. they were going in the clearance section on the bay before the big crack down on aerosols comes along.
« Reply #8 on: September 24, 2010, 06:55:55 pm »
Iv'e checked the members rides and I see no pics!  :wink:
Offline treesimon
« Reply #9 on: September 24, 2010, 08:42:14 pm »
I use neat silicone, I work for a print company and we use gallons of the stuff, it's used to give the paper a shine in magazine.
Always works a treat and doesn't cost me a penny.All I do is give the tyres a good clean with soapy water before applying.
57 plate Tornado red 3dr manual edition 30
  • -Receive: 291
« Reply #10 on: September 24, 2010, 10:04:02 pm »
As above - APC and a good stiff brush will see them clean. Personally I found pressure washing enough to clean my tyres and then dress with something like megs endurance tyre gel applied with a brush to keep them looking good.
« Reply #11 on: September 24, 2010, 10:33:00 pm »
Stealth, you do know it's not advised to directly use the jet wash on your tyres don't you?  :surprised:
  • -Receive: 291
« Reply #12 on: September 26, 2010, 11:35:09 pm »
I don't direct the jet at the tyres directly. They get cleaned when I snowfoam/wash the alloys/arches.
