Alex, is the race file the one that will request 2.0bar when on boost 9?In your opinion what needs upgrading internals wise to support a hybrid turbo?
I know that car. It's a close friend of mine (Cristian). It was a GTI, and he bought the K04 from a friend of mine also. So no hybrid in this one :D420HP is impressive
He was with 9 boost, 9 timing, 9 afr. And at 9 timing, the timing retard was 0 At the wheels the power was 360whp
not sure how i missed your build thread Alex --
Quote from: SteveP on November 05, 2011, 05:35:56 pmAlex, is the race file the one that will request 2.0bar when on boost 9?In your opinion what needs upgrading internals wise to support a hybrid turbo?Same map you have on the Golf. On the ed30 engine it should be just about ok as the hybrid will only hold a little more boost than peak higher. Deffo need rods with this map on a GTi engine even with normal K04 imo.The hybrid is just a larger comp wheel rather than exhaust wheel too. Just not worth going much larger on a K04 as the housings are too small and it will start producing more heat than power. Only really worth going hybrid if your original turbo has died as its not a massive gain.
Quote from: maxitrol on November 05, 2011, 10:39:46 pmnot sure how i missed your build thread Alex -- Where have you been?!
Quote from: TEFF on November 05, 2011, 10:14:36 pmHe was with 9 boost, 9 timing, 9 afr. And at 9 timing, the timing retard was 0 At the wheels the power was 360whpThere is your answer. 360 at the wheels is amazing!
