How much would this be and how easy to fit to Leon Cupra that curently has forge valve?
All you need is the valve, a 38-25mm reducer hose, a 25mm hose joiner, 45mm hose clip and a 25mm hose clip. The reducer hose needs cutting down.
Then needs a vac line from the inlet which you already have for the other forge valve. The N75 valve still needs to be plugged in electronically, but no hoses. This stops any error codes.
I will pop to the car and get some pics of it fitted.
