Author Topic: Weird RNS 510 version C / Skoda Bluetooth Problem  (Read 13403 times)
Offline flyboy1976
« on: October 02, 2010, 12:30:09 am »
Guys this one beats me totally. my RNS 510 version B works fine with my version B skoda bluetooth. When i installed a Version C RNS into my car it kept on throwing a fault code under controller 77 (Telephone) which said 'Open Circuit'on the microphone. Plug the version B back in and it works fine, yet if you use the version C the Mic doesnt work and you get a fault code as mentioned above! so when you make a call no one can hear you.....this one has stumped me. I have voice activation enabled on s/w 2720 that im running on my version B unit and i have treid x2 version C's (one with 2680 the other with 2720) and they both have the same issue but the version B works a treat no fault codes and Mic works as you would assume it to. Do the Version C's have a different pin config on the telephone (green) socket compaired to the older units? it acts as if i dont have the mic connected up when i plug in any Version C unit into my car. I have made sure it is coded correctly as per the version B but im at a total loss on this one! please help guys. the voice command works fine on both units as well, its just when making or receiving calls you can hear the other person but they cant hear you!!!!! HELP!!!!
« Last Edit: October 02, 2010, 12:41:42 am by flyboy1976 »
Offline mortygttdi
  • -Receive: 146
Re: Weird RNS 510 version C / Skoda Bluetooth Problem
« Reply #1 on: October 02, 2010, 03:12:28 am »
I don't know what to suggest other than teaching you how to suck eggs and say are you resetting the c versions after coding? Sorry if you already have tried this?
I know how frustrating it is trying to fathom something out when it seems so easy, but there is possibly something very simple you have just over looked but without seeing the car its hard to say what it might be, but would certainly put it down to the units.
Darren
Offline flyboy1976
« Reply #2 on: October 02, 2010, 08:13:31 am »
yeah did that as i changed the displays from highline to sportsline. it just throws a code 'open circuit' microphone and the mic doesnt work when making or receiving calls, but only on version c units! is there something in the adaption of controller 37/56that im missing? thanks darren in advance. maybe vrscarl has an idea or cameluk?
« Last Edit: October 02, 2010, 09:10:03 am by flyboy1976 »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #3 on: October 02, 2010, 09:16:46 am »
The other suck eggs question is have you got it wired for Voice?
Perhaps worth posting up the coding of 56 & 77.
Stu...
Offline flyboy1976
« Reply #4 on: October 02, 2010, 09:33:34 am »
was just emailing you stu. coding for 77 telephone is set to 0000322 and long coding on controller 37/56 is set to: 04 00 04 02 04 00 00 10 00.  the unit is wired from mic into pins 1 and 7 (in) then from 4 and 9 (out) into BT module pins 11 and 12, works no probs on version B but plug a version C in and it throws an open circuit fault code for the microphone under controller 77 and basically the mic only works for voice activation but not for the phone! help!!!! not that its relevant but i am using the latest gateway. also it makes no difference if i enable or disable microphone diagnostics either, still same problem persists. the only thing i havent got activated or checked is this: http://www.my-gti.com/wp-content/uploads/vw_rns_510_vcds_coding_4.jpg
The problem to me seems like the BT module is picking up a fault between pins 11 and 12 on the BT and not talking to pins 4 and 9 on the sat nav....its as if i havent plugged them in, i checked all connections and they are good, im sure its something with the adaption that you need to activate to tell the sat nav that you are using pins 4 and 9 for microphone, this is my theory.....anyone?
what are shortpress steering wheel buttons exactly? is this mk6 related as i have the later type MFSW controls (i currently have this option unchecked)
i have MFSW / HIGHLINE / and Skoda BT version B for red dot DIS
« Last Edit: October 02, 2010, 10:22:56 am by flyboy1976 »
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #5 on: October 02, 2010, 10:28:25 am »
I've replied to your PM Mate :happy2:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #6 on: October 02, 2010, 10:34:03 am »
What about the coding for microphone diagnostics?
Stu...
Offline flyboy1976
« Reply #7 on: October 02, 2010, 10:45:26 am »
yeah i checked the microphone diagnostics box and made sure it was checked when i put the C's in......im baffled. in my honest opinion its as if the pin config is different on version C's for BT as voice activation works fine, can anyone confirm this please.
Offline flyboy1976
« Reply #8 on: October 02, 2010, 05:13:46 pm »
Can some one tell me what pins on a late version c are used for mic out+ and mic out- please post picture of the units wiring pins config which is ontop of the unit next to the part number please
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: October 02, 2010, 08:27:48 pm »
My gut feeling is a wiring fault but it's odd that it works ok with a B version.  I didn't think the pin outs changed.
Stu...
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #10 on: October 02, 2010, 09:02:44 pm »
^^^ No problems with mine going from a B to C, so I know the pins haven't moved  :happy2:
Offline flyboy1976
« Reply #11 on: October 02, 2010, 09:26:33 pm »
yeah i tried x2 version C units, one with 2680 and the other with 2720 so im lost. my Mic wire has had the proper vw repair wires soldered with shrink wrap attached to the mic lead so basically you have the Mic wire coming from the Mic straight into pins 1 and 7 which is voice activation for the rns 510. Then coming out of pins 4 and 9 into the bluetooth wiring plug pins 11 and 12, i have checked all the connections and they are good. I have the original harness in the car and attached to that is a plug and play harness for the bluetooth (skoda version B) then i have my kufatec MDI plug and play lead attached to that, which goes direct into the back of the sat nav. Guys what on earth am i missing?  :fighting:
Offline mortygttdi
  • -Receive: 146
« Reply #12 on: October 02, 2010, 09:35:35 pm »
Take the MDI out and see if that works?  then take the Bluetooth P&P harness out and plug the green phone connector into the origin car loom and see if the voice control works??
Just try and single some thing out?  other than that and its a big coincidence but you could have 2 duff C version units???
Darren
Offline flyboy1976
« Reply #13 on: October 02, 2010, 09:48:40 pm »
voice control works sweet darren its just when making or receiving calls the mic is dead! as if its not connected but any commands you give the sat nav via voice command work fine.  :drinking:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #14 on: October 02, 2010, 09:56:06 pm »
If Nav Voice works then you know the connection to the RNS is fine, so you should concentrate on the phone section of it.
Try 000402 on your 77.
Stu...
