Author Topic: Weird RNS 510 version C / Skoda Bluetooth Problem  (Read 13418 times)
Offline flyboy1976
Re: Weird RNS 510 version C / Skoda Bluetooth Problem
« Reply #15 on: October 02, 2010, 10:04:35 pm »
what will 0000 402 do stu? i know by changing the 4 to a 3 makes the star button go from bluetooth command to voice command but if i change the x on 00 00 4x2 from 2 to 0 what does that adjust please. also i noticed that under adaption channel 137 was set to 0 on mine, i have set it now to 1 but have no clue what it does??? anyone?
« Last Edit: October 02, 2010, 10:08:09 pm by flyboy1976 »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #16 on: October 02, 2010, 10:09:17 pm »
Have you tried the 402?
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #17 on: October 02, 2010, 10:11:09 pm »
4 - MFSW and Nav unit with CAN
0 - Voice control off or via external device (Ring any alarm bells??)
2 - English Language Display
Stu...
Offline flyboy1976
« Reply #18 on: October 02, 2010, 10:13:10 pm »
tried 422 no result, but would like to replicate the issue on my version B.....at least i then have a starting point lol neither  version C unit i tried had access to the hidden menu screens but i didnt know at the time how to access the adaption but found out how to enable it today but im not sure that would have any bearing over it..... would it?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #19 on: October 02, 2010, 10:14:11 pm »
Not sure anything would be gained from the hidden menu.
Stu...
Offline flyboy1976
« Reply #20 on: October 02, 2010, 10:35:11 pm »
ok just adjusted to 402, i dont have the unit to hand to try but its gotten rid of the bluetooth womans voice (by adjusting 422 to 402) who shouts at you when you select a phonebook entry from the DIS saying '' the number is being dialled'' which i really appreciate, as its drove me nuts for ages and by using the 4 or the 3 makes no difference stu.....should it???? , so i have taken your advice and set it to 4.....i know i havent got it resolved but......
BIG thanks to all you guys on here, stu, darren and carl......big thanks with all the help!  :happy2:
« Last Edit: October 02, 2010, 10:40:58 pm by flyboy1976 »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #21 on: October 02, 2010, 10:45:47 pm »
I would go with the 402 to start with.  Put the RNS back in and let us know how it goes.
Stu...
Offline flyboy1976
« Reply #22 on: October 02, 2010, 11:17:00 pm »
will do, thanks again....one last thing that i have a glitch with is when i make a call to someone via the DIS (i have red dot) and we are in-call,  i cannot select one of the other screens on the DIS! it flicks straight back to the call im in.....  and back to the display saying ''''''calling xxxxx7584'' etc yet other times its ok and allows you to select the MFD, AUDIO or NAV displays! any ideas?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #23 on: October 03, 2010, 12:10:29 pm »
The only time i have encountered that sort of error before is with a firmware that had been modified incorrectly. Usually only with Skoda's though as the PQTable.fli and SKTable.fli files are swapped to get MFSW & Maxidot to work. If it's intermittent i can't see it being that though.
What Firmware is the C version one's on?
Offline flyboy1976
« Reply #24 on: October 03, 2010, 12:41:14 pm »
One was on 2680 and the other was on 2720 both 2010 models
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #25 on: October 03, 2010, 01:06:24 pm »
Ok this is a long shot but update the firmware to 2760 on the C verisons.
Reason being is i vaguely remember reading somewhere about problems with Voice Control/Calling with Skoda B modules with Version C nav's not running 2760.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #26 on: October 03, 2010, 06:46:52 pm »
Have you plugged one in yet to test the new coding??
Stu...
Offline flyboy1976
« Reply #27 on: October 03, 2010, 08:29:06 pm »
no afraid not!  got to go back to the seller and try it.....he has a version B on 2680 so i will try that as well. You dont recon that the other two units (C's) (which i presume are on original software) have to have the software from my-gti.com on them as i have used 2720 and 2760 which i got both from that website. I was wondering if the software online has been adapted somehow differently, as both version C's the seller had wouldnt activate the secret menu by holding down the setup button whereas i know the software online (from my-gti.com) has that adaption already written into  the software so its enabled one the upgrade is complete without having to enable it in VCDS. I know i might be clutching at straws but im open to all and any suggestions at this stage.
« Last Edit: October 03, 2010, 08:32:51 pm by flyboy1976 »
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #28 on: October 03, 2010, 08:49:58 pm »
Try the 2760 firmware I PM'd you with the other day.  :happy2:
Offline flyboy1976
« Reply #29 on: October 04, 2010, 05:39:49 pm »
Guys i checked the wiring today and its all spot on! I was very thorough and made sure all my polarities were ok and they were. Does anyone have a 2010 version C which they can take a picture of the wiring diagram on the top of the unit for me please. Could it possibly be dodgy firnware loaded onto both units i tried. Can anyone help me further please. :sad1:
