Author Topic: Spray painting advice needed.  (Read 3907 times)
« on: October 02, 2010, 12:30:17 am »
I have been wanting to spray the Red lipstick trim on my front grille Silver for months now, and tomorrow is finally gonna be the day.   :star:
But, I am in need of some advice please from you clever peeps. Here are the questions I need help with,  :ashamed:
Will I need to sand the Red trim before using primer and between coats?
If so what grade wet n dry? superfine stuff?
I have a tin of etch primer, is that any good?
After spraying the trim Silver, will I then need to use a clear lacquer?
Is yes to the above, does this procedure seem ok?
Sand -> Primer -> Sand -> Silver -> Sand -> Lacquer
Any Tips or advice on painting/removal/refitting of this trim is greatly appreciated.
Thanks,
Carlo.  :smiley:
Re: Spray painting advice needed.
« Reply #1 on: October 02, 2010, 05:42:43 pm »
any painters online?  :sad1:
Offline damoegan
« Reply #2 on: October 02, 2010, 06:18:57 pm »
You want somethink like a 800 grit wet & dry mate.
Clean the serface down, mask area to paint, key the surface with wet & dry, clean serface again with hot soapy water, dry surface, wipe surface down with a tac cloth or thinners, prime with a few coats of plastic primer leaving enough time between each coat to dry, add a few coats of chosen colour (allow enough drying time again), apply a few coats of laquer (again remember drying time), job done  :smiley:
Always use very thin coats at a time and feel free to flatten back down after each coat with 1200-2000 wet & dry for best results.
HTH
PS. I'm not a painter but my unlce is and thats what he recommended to me and it works just fine.
« Reply #3 on: October 02, 2010, 11:07:53 pm »
Thanks Damo  :happy2: Have you done yours mate? Do you know if the trim comes out easy enough, and also if it clips back in?
I have had the front grill off before and I noticed the clips on the back of the red trim. Do these break easy?  :scared:
Offline damoegan
« Reply #4 on: October 03, 2010, 02:09:09 pm »
No, not done mine mate so I dont know how it comes apart. But thats how I have done parts in the past.
Offline scooba
  • -Given: 18
« Reply #5 on: October 03, 2010, 04:16:18 pm »
Take plenty of time and don't rush between coats allow it to flash off ,if you put to much paint on i think you may have issues on putting it back together .
Offline mortygttdi
  • -Receive: 146
« Reply #6 on: October 03, 2010, 07:53:06 pm »
Carlo I did mine when I had the Gti mask on and you have the right idea just take your time and don't rush it :happy2:
Darren
« Reply #7 on: October 09, 2010, 04:43:02 pm »
Thanks guy's  :happy2: Sorry for the late reply. I marked all my replies as read, by mistake  :ashamed:
Still not got this done yet. Hopefully tomorrow.  :party:
So do I need to flat the silver paint with 1200/2000 wet n dry before the clear coat?
Thanks again.  :smiley:
Offline damoegan
« Reply #8 on: October 10, 2010, 04:54:42 pm »
You dont have to mate  :smiley:
Offline Garth
    • My Build thread
« Reply #9 on: October 12, 2010, 12:13:58 pm »
The problem with painting anything like this is that it will be in the firing line for stone chips. I wrapped mine in silver vinyl so even if it does chip, I can strip and re-apply in 20 mins  :happy2:
I had sprayed my front VW badge to match the car and it still chipped despite me applying a million layers of laquer. Mind you, my windscreen also looks like someone has taken a machine gun to it because of all the stone chips. I guess that's the downside of doing more than 30k miles a year on the motorway  :sad1:
« Reply #10 on: October 12, 2010, 12:24:43 pm »
How easy was it to wrap in vinyl Garth? Sounds like a great idea to me  :happy2:
Any Tips? What size vinyl? etc
Offline Garth
    • My Build thread
« Reply #11 on: October 12, 2010, 12:36:27 pm »
Very easy to do. I actually used Vinyl electricians tape  :grin: Still going strong after a few months. The advantage of this is that a) it's very cheap, b) it's easy to apply and remove and c) if you don't like it, there's no harm done  :drinking:
« Reply #12 on: October 12, 2010, 12:48:36 pm »
Cheers buddy   :drinking:
Now, where to get some silver tape?
I might have a trip down to the local sign writers. The owner used to live next door to my sis. I will see what he reckons. There is also a good chance that he can print a good Reflex Silver match.
 :wink:
Offline Garth
    • My Build thread
« Reply #13 on: October 12, 2010, 01:29:09 pm »
 :wink:
Try ebay  :grin:
Search for silver electrical tape or something similar  :happy2:
« Reply #14 on: October 20, 2010, 01:09:20 pm »
Well I finally got round to doing the stripe in Silver  :happy2:
£3.50 for a 10m roll of 25mm Silver Vinyl (go-faster stripe stuff from local car accessory place)  :wink:
Worked a treat.
