Author Topic: Can bus gateway confusion  (Read 14873 times)
MPS
Re: Can bus gateway confusion
« Reply #15 on: October 06, 2010, 09:30:30 pm »
Another thing I noticed the gateway seems to perch on a bracket which can be tilted downwards very easily, they obviously didn't screw it down tight from factory. Doing that probably won't make the job any easier though  :grin:
Offline vr6t
« Reply #16 on: October 06, 2010, 09:32:49 pm »
No problem!!
Just make sure you take screen shots of the current coding of the gateway including the long coding screen   :wink:
"A mk5 gti why did you buy that??" Quote of the week from trouble and strife...
MPS
« Reply #17 on: October 06, 2010, 09:35:32 pm »
Yep, done that already, followed the guide on my-gti.com!  :happy2:
Offline vr6t
« Reply #18 on: October 06, 2010, 09:37:50 pm »
Yes it just clips onto a metal bracket above the clutch peddle, make sure it is clipped on when you try to push out the gateway from the bracket.
At one point when i was doing mine i did try to pull it off completely but it attached better on the right hand side. :confused:
Offline mortygttdi
  • -Receive: 146
« Reply #19 on: October 07, 2010, 01:11:26 am »
Matt no its an actual metal bar which is shaped at one side and flat on the other so it can be bolted to the s/rack.
The only other easy way to do it is by taking the plastic trim from either side of the steering column, basically so all the plastic trim is out. If you sit in the car and look forward of your left knee its directly behind that panel.
It makes it harder once you have hold of it cos there is no play in the harness!!!
Darren
MPS
« Reply #20 on: October 08, 2010, 12:03:19 pm »
Quick update, stripped the dash right down, taken the right hand panel off surrounding the lower part of the steering column, just need a right angled tool to take the remaining T20 screw out from near the ashtray then the left hand panel will come out easy (I hope)
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #21 on: October 08, 2010, 12:17:10 pm »
Tricky little sucka eh.
Maybe post a picture up so someone could more easily describe what to strip out.
Stu...
MPS
« Reply #22 on: October 08, 2010, 08:50:21 pm »
Sorted, Canbus Gateway now swapped, easy when the dash panels surrounding the steering wheel are removed! Got another problem now though, I'm doing an MDI armrest install and after routing the mdi lead through, I've found it isn't long enough!  :confused:  :scared: :sad: It needs to be about 10cm longer at the very most and then It would be fine! I can't believe it's too short, I wonder if the lead was only meant to be used in conjunction with the glovebox mounted MDI instead?
Offline vr6t
« Reply #23 on: October 08, 2010, 09:55:30 pm »
I have read a post of someone getting this to work :confused: I did think the wiring was a bit on the short side.
I finished off fitting my MDI this morning, what a pain. I took out the clove box and it has 4 electrical connection and the aircon pipe.
Got it all fitted and working now  :jumpmove:
MPS
« Reply #24 on: October 08, 2010, 10:27:35 pm »
Yes the difference with mine though is: the mdi lead isn't long enough to be able to plug the quadlock into the back of the radio as well. Bloody hopeless, I bought it from a German ebay shop, I would probably have been better making the lead myself!
Offline mortygttdi
  • -Receive: 146
« Reply #25 on: October 08, 2010, 11:47:26 pm »
chop shop
Extend the wires to your desired length if your handy with a soldering iron and shrink tubing :happy2:
Darren
Offline flyboy1976
« Reply #26 on: October 09, 2010, 01:45:11 pm »
it should be just about long enough are you talking about this lead:
http://www.kufatec.de/shop/product_info.php/info/p1113_c26_MEDIA-IN-MDI-Interface---Harness---VW-Golf-5.html
it should be routed down the drivers side centre console and along up through the armrest where the cd changer would normally go!
MPS
« Reply #27 on: October 09, 2010, 07:58:13 pm »
No, I bought http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=310228786869 this one from an ebay store in Germany.
I've taken it out now, I don't think I'll bother with the MDI setup and just use the SD card feature on the RCD510, much less hassle. I'm going to get a refund on the MDI loom as it is not fit for purpose.
I've got the can gateway and radio installed OK now though. The RCD510 is ace and there is a definite improvement in sound quality over the RCD300!  :congrats:
I now have a different problem though, I've recoded the CAN gateway Installation List to match the tick boxes from the old gateway but after a fault code scan it gave the following error code
01044 - Control Module Incorrectly Coded.
What have I done wrong?
Matt
Offline flyboy1976
« Reply #28 on: October 09, 2010, 08:17:32 pm »
look at your long coding under radio...copy and paste it for me or tell me what items you have or havent got selected what do you have on your car? mfsw? highline?
MPS
« Reply #29 on: October 09, 2010, 09:59:29 pm »
Long Coding under Radio is: 0000040004
No MFSW or Highline dash.
