Author Topic: Can bus gateway confusion  (Read 14875 times)
Offline flyboy1976
Re: Can bus gateway confusion
« Reply #30 on: October 09, 2010, 10:42:40 pm »
break down what is what for me, what do you have checked or unchecked?
MPS
« Reply #31 on: October 10, 2010, 11:35:19 am »
Channel 56 - Radio - Long Coding helper
Byte 0:
Bit 0: AUX-IN access restricted - unticked
Bit 1: CD-Changer/ipod/USB Connection Monitoring active - unticked
Bit 2: AUX-IN connection monitoring active - unticked
Bit 3: Parking Aid installed - unticked
Byte 1:
Bit 0-7: 00 Sound system not installed
Byte 2:
Bit 0-7: 04 4 Speaker Channels (2 Passive speakers each front and rear)
Byte 3:
Bit 0: Shortpress steering wheel buttons installed - unticked
Bit 1: Telephone OR Telephone Preparation (CAN) installed - unticked
Bit 6: Back-up camera installed - unticked
Byte 4:
Bit 0-7: 04 Treble Speaker monitoring for front & rear speakers active
HTH,
Matt  :happy2:
P.S. Here is screen capture of the fault code from Channel 19 - CAN Gateway
Sunday,10,October,2010,11:37:50:13314
VCDS Version: Release 908.0
                Address 19: CAN Gateway       Labels: 1K0-907-530.lbl
Control Module Part Number: 1K0 907 530 S    HW: 1K0 907 951
  Component and/or Version: J533  Gateway   H07 0071
           Software Coding: C9817F06000202000003
            Work Shop Code: WSC 28022 210 90954
Fault Codes have been Erased
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Mileage: 88943 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:37:50
Matt
« Last Edit: October 10, 2010, 11:41:49 am by MPS »
Offline flyboy1976
« Reply #32 on: October 10, 2010, 11:48:00 am »
thats your gateway thats coded incorrectly, something is slightly different with the S version to the previous version you had installed???? you could copy and paste the long coding from the gateway in the same fashion and i will take a look for you.
Offline flyboy1976
« Reply #33 on: October 10, 2010, 11:51:26 am »
was the gateway purchased second-hand?
MPS
« Reply #34 on: October 10, 2010, 12:08:02 pm »
The Gateway was bought off ebay, supposedly new according to the seller and it came in the original vw parts box so probably is.
The long coding from the Gateway is: C9817F06000202000003
Thanks!
You cant copy the long coding string from the old gateway either can you cause there are more bytes in the S revision.
« Last Edit: October 10, 2010, 12:19:10 pm by MPS »
MPS
« Reply #35 on: October 10, 2010, 12:24:49 pm »
 :scared: :scared: :surprised: I think it's draining my battery as well  :scared:
Offline flyboy1976
« Reply #36 on: October 10, 2010, 12:31:52 pm »
revision S shouldnt drain your battery. break down that long coding for me please.
Offline flyboy1976
« Reply #37 on: October 10, 2010, 12:34:11 pm »
and what car is it on? GTi? R32? 3 door or 5 door?
MPS
« Reply #38 on: October 10, 2010, 12:38:04 pm »
The car is a 5 door GTI on a 55 plate.
Is there a quicker way for me to copy the data from each individual screen, I've been typing it manually cause it won't let me copy and paste.
I'm running VCDS 908, for the record.
Offline flyboy1976
« Reply #39 on: October 10, 2010, 12:51:26 pm »
PM'd
MPS
« Reply #40 on: October 10, 2010, 01:09:32 pm »
Replied!  :happy2:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #41 on: October 10, 2010, 02:04:09 pm »
You could do a series of screen shots.
I have also coded controllers via MSN remote admin before.  :signLOL:
Stu...
