Author Topic: Help urgently needed with failed start following ITG!!  (Read 1288 times)
Offline RagingKileak
« on: October 05, 2010, 08:01:56 pm »
Gents,
Fitted a second hand ITG Maxogen and following trying to redraft the car... Just turns over, runs for less than a second and dies!
I think the problem is MAF related as when I leave the MAF OUT of the socket, the car runs ok (obviously I don't wanna run it like that for long!
So... I have an additional MAF which does the same.
All hoses are tight etc, nice and smoothly ran through the bay etc. No kinks, gashes, or anything else.
Any help appreciated as I'm stuck on my mates drive!!
Matt
Offline Poppa Dom
Re: Help urgently needed with failed start following ITG!!
« Reply #1 on: October 05, 2010, 08:14:00 pm »
Check your turbo hoses to the fmic, might have popped off. I have had the same symptom, issue was with poising the turbo hose. Worth a check.
« Reply #2 on: October 05, 2010, 08:25:25 pm »
Fixed chaps.
Basically, MAF was in backwards because the 3 inch long bit of metal it sits in was backwards!!
Sigh!
Matt
Offline Poppa Dom
« Reply #3 on: October 05, 2010, 08:28:01 pm »
Glad you are sorted and back on the road :happy2:
« Reply #4 on: October 05, 2010, 08:47:23 pm »
Cheers mate!
Hopefully serve as help for others too!
Only bit you could conceivably get wrong I'd say!!
Matt
