Author Topic: Please read  (Read 1599 times)
Offline Eddy30
Please read
« on: October 05, 2010, 08:08:31 pm »
Hi all,just drive home from work and when pulling mediumly hard in 3rd 4th and 5th gear as the car hits 3000 revs the car stutters andjudders then carries on pulling and I get s light flashing on the dash for about 20seconds ( the one that looks like an engine). Then goes off. Can anyone give any advice on what it can be?I appreciate it cannot be solved on here but I'm seriously broke so I have to keep using it and may only get chance to have it looked at at the weekend. Also would this flashing light log a code or anything? Thanks in advance I'm stuck between a rock and a hard place.
Offline TrickGTI
Re: Please read
« Reply #1 on: October 05, 2010, 08:18:49 pm »
Could be one of the ignition coils breaking down under load creating the juddering i.e missfire?? or can you not tell?? very likely to be this if its only doing it under load.. hope this helps if the light has come on then yes.. the little engine light will only come on if the car sees the fault happen more than three times in a row if it only see the fault everynow and then it wont come so if you know anyone with vagcom get her plugged in  :happy2:
2006 Tornado red GTI
Offline Poppa Dom
Re: Please read
« Reply #2 on: October 05, 2010, 08:30:23 pm »
Sounds like a coil pack, anyone local to you with vcds. This is the only way you can be certain really, without logging the codes we can only speculate.
Re: Please read
« Reply #3 on: October 05, 2010, 08:42:58 pm »
Yep I'd say 100% that was a coil pack.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
Re: Please read
« Reply #4 on: October 05, 2010, 09:59:23 pm »
x3 coilpack on the way out  :happy2:
confirm by VCDS then replace effected cylinders
Red ED35 5dr DSG
BLOG | BUILD
Offline Eddy30
Re: Please read
« Reply #5 on: October 05, 2010, 10:08:08 pm »
Thankyou chaps really appreciate you replying,will try gettin it plugged in this weekend,just hit 65k and they don't appear to have been done so hopefully it's just this.
Offline candy turbo
Re: Please read
« Reply #6 on: October 05, 2010, 10:11:00 pm »
i would try not to use the car too much till you get it sorted this can lead to more problems  :happy2:
Re: Please read
« Reply #7 on: October 05, 2010, 10:13:50 pm »
I had to do 90 miles knowing I had a faulty coil pack. I'm sure as long as you don't use more than around 50% throttle you will be ok.  :happy2:
Offline Eddy30
Re: Please read
« Reply #8 on: October 05, 2010, 10:43:25 pm »
Ok thanks,luckily it's only anshort commute to work,are the coil packs and spark plugs ed30 specific?
