Author Topic: Error codes  (Read 23928 times)
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
Re: Error codes
« Reply #15 on: November 03, 2008, 07:29:56 pm »
ah i see. That delay must cost performance time though yes?
Well, you will suffer a slight delay from a touch more turbo lag.
Is there any difference between an OEM recirc valve and an aftermarket one?
Functionwise - no.  Construction - yes.
The OEM one uses a rubber diaphragm, which is reported to be prone to tearing, but the latest releases of the OEM one seems to be more reliable.  Higher boosts from remaps seem to aggravate the life span.
An aftermarket one like the Forge uses a piston with O rings, and is considerably more durable, though still needs "servicing".  The Forge ones look  8)  8)  8)  8) though.  :wink:
  • -Given: 88
  • -Receive: 95
Re: Error codes
« Reply #16 on: November 03, 2008, 07:32:36 pm »
How do you fit an R32 exhaust to a GTI?  CAT Back only?
Unless it is just the rear box - similar to the way RedRobin has the quad tips on his???
If indeed your car is a GTi then the Forge DV is doing the work of the Turbocharger bypass control valve, or not in your case
Yup, agreed.  But a correct log of the N75 should give a clearer diagnosis.
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Error codes
« Reply #17 on: November 03, 2008, 07:45:42 pm »
Is it also possible that some of those codes were already present from the Forge fitting?
Have you cleared them off and then checked again?
Stu...
Offline 182_blue
  • -Receive: 54
Re: Error codes
« Reply #18 on: November 03, 2008, 07:47:10 pm »
i think so, he said "The last code didnt repeat but the top three did after being reset." , still not sure what program there using though
  • -Given: 88
  • -Receive: 95
Re: Error codes
« Reply #19 on: November 03, 2008, 07:54:29 pm »
I agree.
I have had a right nightmare with a £20k Snap-On reader (I think it was Solus) - utter shyte, and grossly over-rated.  Unfortunately, the collegue who owns it has it on the knock, so can't really get rid of it.  It reapeatedly gave the wrong codes on my last S4, failed to interrogate many of the modules, and completely missed a reading from the ESP ECU.
Unfortunately, many of these so called fault code readers, even the professional ones, don't actually read the manufacturer specific codes.  They only read the generic EOBD or OBD2 codes, which are just really basic codes.
Offline 182_blue
  • -Receive: 54
Re: Error codes
« Reply #20 on: November 03, 2008, 07:56:15 pm »
perhaps if we know where he is one of us will be able to get him hooked up with Vag com
  • -Given: 88
  • -Receive: 95
Re: Error codes
« Reply #21 on: November 03, 2008, 07:59:56 pm »
I think from his "welcome" thread, he stated he was from Scotland-shire!
Offline 182_blue
  • -Receive: 54
Re: Error codes
« Reply #22 on: November 03, 2008, 08:03:19 pm »
well, we must not hold it against him  :laugh: :laugh:
Offline Duffy
Re: Error codes
« Reply #23 on: November 03, 2008, 08:04:45 pm »
With regards the exhaust system, its and r32 Style system created by Milltek for the GTi. Its cat back yes but you can get a turbo back system from milltek aswell.
Im from not so sunny or warm glasgow. The place i go to is called Drivers ltd. There supposed to be best in the city and when i spoke to them said they were going to put it on the VAG-COM system.
Offline Duffy
Re: Error codes
« Reply #24 on: November 03, 2008, 08:05:23 pm »
 :jumping: Were not all crazy!!
  • -Given: 88
  • -Receive: 95
Re: Error codes
« Reply #25 on: November 03, 2008, 08:12:00 pm »
Ahh, but do you have ginger hair and drink Special Brew - or is it McEwans?  :wink:  :evilgrin:  :evilgrin:  :evilgrin:  :evilgrin:
Offline Duffy
Re: Error codes
« Reply #26 on: November 03, 2008, 08:31:41 pm »
lol i do not have ginger hair nor drink that stuff. Truth be told after a holiday away i am not hooked on Corona. Random i know.
