Author Topic: Best reasonably priced brakes  (Read 3479 times)
Offline Weston
« on: October 07, 2010, 07:48:41 pm »
Getting remapped soon so would like to explore the possibility of better than standard brakes without spending ££££ for a completely new setup. I find the current ones ok till I s#%¥ myself on a corner this afternoon!
So my question is simply what discs and/or pads give the best improvement for the best price? I don't particularly want to change anything but the discs and pads but am open to persuasion  :smiley:
GTI going...
Re: Best reasonably priced brakes
« Reply #1 on: October 07, 2010, 10:50:45 pm »
Depends what you plan to do with the car, if it's just for fast road use, the the R 32 set up should be more than enough for your needs. if you plan to do a bit more ie the odd track day then you may want to get a bit more serious.  :driver:
« Reply #2 on: October 07, 2010, 10:57:25 pm »
The "not quite so big brake thread" is quite a good read.  :wink:
Offline Janner_Sy
  • -Receive: 113
« Reply #3 on: October 08, 2010, 04:02:13 pm »
A Set of performance pads would be a huge improvment for only a small outlay
Offline Weston
« Reply #4 on: October 08, 2010, 06:41:29 pm »
Thanks, that was a good read. Lots to think about.
GTI going...
Offline Weston
« Reply #5 on: October 08, 2010, 06:42:39 pm »
Would you recommend any in particular? New pads could be a good quick fix
GTI going...
Offline Janner_Sy
  • -Receive: 113
« Reply #6 on: October 08, 2010, 06:49:22 pm »
people n here highly reccomend ferrodo DS2500s, mintex M1144s etc.  daveB is the man to talk to when it comes to pads
Offline Syrag64
« Reply #7 on: October 14, 2010, 11:32:48 am »
I've gone for the Porsche caliper 4 pot set up on mine nicely re-furbed by DaveB (not fitted yet tho :ashamed:)
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
Offline Weston
« Reply #8 on: October 14, 2010, 04:33:25 pm »
I like the sound if that setup  :smiley:
GTI going...
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #9 on: October 15, 2010, 07:41:18 am »
ask Dave B stating your requirements.
I'd say R32 setup  or the porsche calipered 'not so big brake kit'
the latter being my preferred choice at the moment  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline markc
« Reply #10 on: October 15, 2010, 08:00:34 am »
Or....   try pads first, see how you like them, or not.
On my next pad change I will be trying Tarox's Strada fronts on a stock caliper and disc (they are about 100 notes from Awesome GTI).   They get very good reviews by the way !!
http://www.awesome-gti.co.uk/product.php?xProd=11718&xSec=150
« Last Edit: October 15, 2010, 08:02:19 am by markc »
Had: Edition 30, 3 Door Manual, Pearl Black, Cruise Control, IPod Prep, Arm Rest, Auto Lights and Wipers
Offline Janner_Sy
  • -Receive: 113
« Reply #11 on: October 15, 2010, 12:34:11 pm »
as said in postin my replies pads are a huge improvement IF you get good ones. @ markC i can assure you that the tarox strada pads are sh!te.  I suffered near catastrophic fade with them at the ring( this was with motul rbf600 FLUID), to the point of i wasted an entire lap by having to drive slow to allow them to cool as they had just stopped working. I CHANGED TO DS2500 pads which were light years ahead in performance
Offline markc
« Reply #12 on: October 15, 2010, 01:23:19 pm »
Hmmm, well they do get very good reviews ont' web  :surprised:!   But I'll go with your review then, and not bother if they are that bad  :sad1:
Offline Janner_Sy
  • -Receive: 113
« Reply #13 on: October 15, 2010, 06:22:23 pm »
i bought them from awesome on a deal alongside the zero sixty discs.  wouldnt do that again personally.  good fluid, good pads and off you go
Offline Weston
« Reply #14 on: October 15, 2010, 07:08:37 pm »
Thanks for all the replies. Thinking ds2500 pads is the way to go. Not sure if I should just get them for the front, or if I should change the discs as well. So many options  :rolleye:
GTI going...
