Author Topic: Car stalls when stationary  (Read 1784 times)
Offline big al
« on: October 09, 2010, 12:28:12 pm »
Hi guys, having come back from up north just to pick up a spare set of wheels, drive was fine there, and coming back, until I pulled off the motorway and was sat at a junction, and the car suddenly cut out, engine died, and battery warning light came on. Turned the engine off and on again, and pretty much fine, but then every time I stopped after that it cut out and the battery light came on.
Does anyone know the cause of this? Is it just a case of buying a new battery? or something more sinister? When I pulled onto my drive, with the engine on, the rev meter was flicking to 1100, then back to 600 and kept doing that even though car was in neutral.
(I have done a search for this, but only found one about the car almost cutting out, which could be the same problem as mine, but wanted to make sure!)
Offline singh123
  • Seat Leon Cupra
Re: Car stalls when stationary
« Reply #1 on: October 09, 2010, 01:37:31 pm »
Al if you want i can do a vcds scan too see if any error codes come up let me know :happy2:
Seat Leon Cupra
Offline big al
« Reply #2 on: October 09, 2010, 07:30:42 pm »
That would be great thanks mate,
Gonna speak to local garage to see if they can diagnose it over the phone, but failing that will def take you up on the offer,
Offline singh123
  • Seat Leon Cupra
« Reply #3 on: October 09, 2010, 07:53:48 pm »
No probs Al let me know hopefully its nothing to serious, does it drive fine once you moving ie no loss in power might be a loose pipe.
Seat Leon Cupra
Offline big al
« Reply #4 on: October 09, 2010, 08:12:21 pm »
Nope fine, Pulling away is a bit jerky, but that is probably something to do with the engine only just starting and the revs being off.
Offline big al
« Reply #5 on: October 10, 2010, 08:51:50 pm »
Thought I would start it up today to see how it was, the rev needle is all over the place, sounding like its about to stall, and just coughing and spluttering all the time, didn't try to drive it, just wanted to see if it was any better/worse than yesterday? Will prob have to sort out the VCDS, but wanting to know if anyone may know what is causing it.
Offline vRSAlex
  • -Receive: 253
« Reply #6 on: October 10, 2010, 08:53:47 pm »
Boost leak?  One of the bottom hoses from the intercooler.  Do you have a forge dv?  The top cap can come loose and cause leaks.
Follow AKS tuning on Facebook
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #7 on: October 10, 2010, 09:39:16 pm »
could it not be a leak or faulty PCV system, loss of vacum can affect the engine idle, http://www.mk5golfgti.co.uk/forum/index.php?action=printpage;topic=15111.0
Offline big al
« Reply #8 on: October 10, 2010, 10:57:17 pm »
Think it is probably a broken PCV. Been looking on google and seems likely.
There is what seems like a bit of spray on my Forge pipes, Not sure if htat is connected.
Will I be OK to drive to the garage if it is a broken PCV?
Offline skifast
« Reply #9 on: October 11, 2010, 12:22:27 am »
i'm sure you would notice or have checked-but on the off chance,have you checked that the oil filler cap is on tight.
Offline vRSAlex
  • -Receive: 253
« Reply #10 on: October 11, 2010, 06:25:24 am »
Or the dipstick has popped up
