Author Topic: Swapping cluster lights from blue to White  (Read 2615 times)
Offline Lyons
  • -Given: 18
« on: October 12, 2010, 10:32:59 pm »
Has anyone ever successfully swapped the blue of the instrument dials and the climate displays to white?
I imagine the latter shouldn't be too tricky, but what about the former?
Any info appreciated.
Re: Swapping cluster lights from blue to White
« Reply #1 on: October 12, 2010, 10:40:51 pm »
I think Darren will know (Mortygttdi) I think he once mentioned changing the white dot matrix display too (highline)
Offline Lyons
  • -Given: 18
« Reply #2 on: October 12, 2010, 10:43:03 pm »
Aye, I can recall something about swapping the highline.
Sadly I just have a midline, but I'd settle for swapping the blue to white.
  • -Receive: 291
« Reply #3 on: October 12, 2010, 11:52:04 pm »
The blue light can be changed but it's a bit of a pig. There are these tiny mounted devices that are smaller than LEDS. You need to replace something like 20 of them.
Offline mortygttdi
  • -Receive: 146
« Reply #4 on: October 12, 2010, 11:54:45 pm »
Speak to Garth I know he did his so could give you some advice.
Darren
Offline Lyons
  • -Given: 18
« Reply #5 on: October 13, 2010, 06:22:00 am »
Is that for the cluster?
I'll send him a pm, cheers Darren.
I've a mate that does vauxhall SMD conversions and has said if I can remove both parts he'll give it a go. From memory the cluster removal is quite easy, and I'm assuming the climate control is just the next thing to be removed after taking out the trim for a HU swap.
If I remove the cluster will it need recoding when i put it back, or is that only if you put a new one in?
Offline Garth
    • My Build thread
« Reply #6 on: October 13, 2010, 06:44:21 am »
I've done this on mine. Take a look in my build thread (link in my signature) for details. Not massively difficult but then it is easy to mess up if you aren't careful!
Offline Lyons
  • -Given: 18
« Reply #7 on: October 13, 2010, 07:23:20 am »
Found your thread this morning Garth, PM sent with a couple of questions!
