Author Topic: fitting THS side engine mounts...  (Read 18099 times)
Offline vRSAlex
  • -Receive: 253
Re: fitting THS side engine mounts...
« Reply #15 on: October 14, 2010, 06:25:41 am »
Just to let everyone know that I have never had an issue with re using any of those bolts.  Not even VW bother with new ones.
Follow AKS tuning on Facebook
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #16 on: October 14, 2010, 07:43:57 am »
cheers Alex  :happy2:
same torque settings too? and would you use threadloc ? (I know some people shy away as it changes the torque settings)
Red ED35 5dr DSG
BLOG | BUILD
Offline vRSAlex
  • -Receive: 253
« Reply #17 on: October 14, 2010, 09:59:04 am »
I wouldnt worry about the threadloc.  Just set to VW specs and you should be fine.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #18 on: October 23, 2010, 06:23:32 pm »
Thanks for the torque guide John_o  :happy2:
Did mine this afternoon and I a really impressed the quality is top notch and had made a noticeable difference straightaway without being too invasive in the cabin  :party:
Offline Cupra R
  • -Given: 18
« Reply #19 on: October 23, 2010, 07:16:05 pm »
How long did it take you Steve?
Offline RobH
  • Revo stg 2+
« Reply #20 on: October 23, 2010, 07:28:16 pm »
Tut tut you should have fitted the these for the pod Rich :rolleye:
Off the line grip is a good improvement :happy2:
Offline Cupra R
  • -Given: 18
« Reply #21 on: October 23, 2010, 07:34:29 pm »
I know mate, but I just haven't had the time.  I'd only just finished work when I phoned you earlier.  Busy busy lately at work.
P.S.I told you I aint no good at drag races anyhow, I'm sure these wouldn't of helped me out lol.  Now on the track, that's a different matter  :P
« Last Edit: October 23, 2010, 07:36:15 pm by Cupra R »
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #22 on: October 23, 2010, 08:13:02 pm »
Just over an hour for the side mounts  :happy2:
Offline Cupra R
  • -Given: 18
« Reply #23 on: October 23, 2010, 08:22:18 pm »
Thanks Steve.  :drinking:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #24 on: October 23, 2010, 08:25:12 pm »
No probs, it's very easy to do and I certainly wouldn't be paying anyone to do these if you have the tools available.  :happy2:
Offline Cupra R
  • -Given: 18
« Reply #25 on: October 23, 2010, 08:32:57 pm »
TBH I haven't really looked into doing them yet as I just haven't had the chance.  Does much need removing or anything?  Did you just support the engine from underneathe then change the mount's?
Any pointer's you can give would be appreciated  :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #26 on: October 23, 2010, 08:55:40 pm »
THe below is all off the top of my head could be slightly wrong: -
Tools Needs: -
19, 13 & 10mm Sockets
16mm deep Socket
Couple of medium and long extension bars
T20 Torx Screwdriver
Jack and a wooden block to support the engine
Also found a magnetic pick up tool very helpful  :grin:
On the drivers side mount I removed the bolts/screws for the washer filler neck, charcoal cannister and expansion tank, then unbolted the side support bracket. Then you can get at the mount, that's unbolted by removing the2 x 16mm bolts and 2 x 19mm bolts.
Pics of the driver side mount: -
This side done: -
For the passenger side mount, the battery and battery tray (3 x 13mm bolts) need to be removed, then unclip the wiring loom tray the rest on top of the mount. Then unbolt the three 19mm bolts on the engine side of the mount and the 4 x 19mm.
Pics of the Passenger side: -
This side done
HTH  :happy2:
Offline Cupra R
  • -Given: 18
« Reply #27 on: October 23, 2010, 09:00:23 pm »
Steve.  That is blumming perfect mate.  Thanks very much.
Now all I need is the time to be able to start and finish it.  :happy2:
Nice one.  :drinking:
h4rdy
« Reply #28 on: October 23, 2010, 10:38:03 pm »
Steve,
Maybe a silly question, but do you need to support the engine or because your only changing one at a time you don't need too?
J
Offline vRSAlex
  • -Receive: 253
« Reply #29 on: October 24, 2010, 10:15:36 am »
Steve,
J
Yes you do need to as the lower mount cant support the weight.
Steve, you say use a deep 19mm socket, but dont you mean a deep 18mm?
