Author Topic: EPC  (Read 2766 times)
Offline boxxer1973
EPC
« on: October 14, 2010, 09:15:18 pm »
Just had Revo installed and am now getting the EPC light on after a spirited session any help?
Mk5 golf Gti REVO. stg2+
Milltek | Auto tech | White line | Forge | REVO | KW | Quaife | helix clutch |
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
Re: EPC
« Reply #1 on: October 15, 2010, 04:02:34 pm »
Hello,
Its telling you there is summat not right with your car, you have got an under laying issue which has been highlighted due to the added power, it could be a maf, dv, pcv fuel, coil packs ect...
Your best be is get it back to the dealer who flashed the map to the car and ask them to carry out a diagnostics session.
Nick
01455 617233
Offline boxxer1973
Re: EPC
« Reply #2 on: October 19, 2010, 09:23:02 am »
VCDS said it was a peddle sensor, came up about 20 times in 1 day, just checked all connections from TB to peddle and so far so good no fault.
Happy days Loving the power.
think its set as
boost=8
timing=4
fuel   =9
I do feel the boost is a little high any advice ? :driver:
Offline R-tech-Nick
  • -Receive: 30
Re: EPC
« Reply #3 on: October 30, 2010, 04:26:54 pm »
think its set as
boost=8
timing=4
fuel   =9
What engine you got?
01455 617233
Offline boxxer1973
Re: EPC
« Reply #4 on: October 30, 2010, 07:32:09 pm »
2.0 tfsi
Offline PDT
  • -Receive: 142
Re: EPC
« Reply #5 on: October 30, 2010, 11:55:19 pm »
Boost setting seems normal, if thats how it was set up on the dyno / on road after datalogging then the installer would have done so for a reason.
As for the fault, its not one I have come accross on the Tfsi so cant help much sorry
Offline boxxer1973
Re: EPC
« Reply #6 on: October 31, 2010, 11:28:53 am »
fault seems to have cleared now. Dealer reckoned it could have been the throttle angle sensor adapting to the new settings
