Author Topic: CAN gateway  (Read 2414 times)
Offline simonp
  • -Receive: 38
  • No longer a Golfer
CAN gateway
« on: October 17, 2010, 11:57:18 am »
Need to update mine.
Question: is it cheaper to go to a dealer than ebay (95 squids on there) and will I be able to buy it cheaper at a Skoda or Seat dealer, rather than a VW one?
MPS
Re: CAN gateway
« Reply #1 on: October 17, 2010, 01:12:14 pm »
Cheaper off ebay. A best offer of £75 to these guys usually works!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180572923211
VW Main dealer I think you're looking at around £140 for the same part.
Offline dajonic
  • -Given: 17
Re: CAN gateway
« Reply #2 on: October 17, 2010, 01:18:12 pm »
And where abouts are these little beauties hidden away in the car?
MPS
Re: CAN gateway
« Reply #3 on: October 17, 2010, 01:31:29 pm »
Don't ask! I spent about 4 hours retrieving mine last weekend. The easiest way I found was by removing the 2 dash panels which cover the part beneath the steering wheel. Depending on the model year of your car it'll either be perched on a bracket above the pedals OR behind the relay panel. Mine was in the former location and proves a bit of a bitch to get off! The dash panel removal requires a screwdriver with a Torx T20 size bit and a right angled socket with a T20 adaptor for undoing the hidden screw underneath the panel on your centre console.
MPS
Re: CAN gateway
« Reply #4 on: October 17, 2010, 01:32:16 pm »
A Haynes manual might help!
Offline simonp
  • -Receive: 38
Re: CAN gateway
« Reply #5 on: October 19, 2010, 01:11:11 am »
Righto, it's bought. Coding now: am I right in thinking that it's merely a matter of ticking the correct boxes for the kit on the car and then the unit writes its own long code(s) accordingly?
Not that I've got VCDS mind!
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: CAN gateway
« Reply #6 on: October 19, 2010, 05:26:49 am »
First you need to write down or print screen the one you have in, otherwise you're lost as to what boxes to tick  :wink:
Over the top mod list ;o)
Offline simonp
  • -Receive: 38
Re: CAN gateway
« Reply #7 on: October 19, 2010, 03:38:34 pm »
Is that all there is to it, though? I read somewhere about the gateway needing to be changed from LHD to RHD, too?
Offline mortygttdi
  • -Receive: 146
Re: CAN gateway
« Reply #8 on: October 21, 2010, 07:29:29 pm »
Yes in long coding the last byte is for country coding and manufacturer in drop down boxes, so you will need to choose vw and rhd otherwise you will get a fog light out warning on your dash.
Darren
