Author Topic: Keyfob query  (Read 2531 times)
Offline AnilS
  • -Given: 50
Keyfob query
« on: October 17, 2010, 04:01:48 pm »
Guys, can you help?
Wife's Golf is having a service this Thursday at Sutton Coldfield VW (Venture) and found that the spare key has a flat battery (lack of use). They are charging £3 for a replacement battery but if the car needs coding, it jumps to £50. Heard of this one before?
Ta. :happy2:
Offline Thor
  • -Receive: 25
Re: Keyfob query
« Reply #1 on: October 17, 2010, 04:28:47 pm »
Just change the battery yourself, heres a how to with pictures http://www.riskin.org/vwkey/, obviously at your own risk.
Can't see why it would need coding, but i stand to be corrected by those in the know.
HTH
                                     Mk6 GTI
Offline AnilS
  • -Given: 50
Re: Keyfob query
« Reply #2 on: October 17, 2010, 04:38:54 pm »
Thank you. Not feeling that brave if they do it for £3 but its the "Sorry Sir, but it'll need reprogramming" that I don't want to hear :laugh:
I've saved that guide as a favourite and see what they say. Any more advice welcome.
Offline JPW
Re: Keyfob query
« Reply #3 on: October 17, 2010, 06:53:41 pm »
Anil,
If it is flat then the chances are that it will need recoding.
I'm not at home at the moment, but I'll PM you the instructions.
I'm assuming it's you from the RX8OC!
I'm over here on the darkside now ;-)
John (JWatts from RX8OC)
* Just checked and the link that I had has gone Anil - I'll see if I saved it somewhere.
« Last Edit: October 17, 2010, 09:47:30 pm by JPW »
Reflex Silver with a few toys :-)
Offline AnilS
  • -Given: 50
Re: Keyfob query
« Reply #4 on: October 17, 2010, 11:49:47 pm »
John, you've tracked me down  :signLOL:
How you doing mate?
I'll get the battery done by them and hope you can find the link. :happy2:
Nice hearing from you again :happy2:
Offline JPW
Re: Keyfob query
« Reply #5 on: October 18, 2010, 08:45:18 pm »
Very well.....you have PM, give it a go.
Offline GTiBEER
  • Golf Loving Mo Fo
Re: Keyfob query
« Reply #6 on: October 18, 2010, 08:56:44 pm »
Ive got a brand new key that I am taking in on Wednesday morning to be coded. It is still in the VW wrapper so i do not know if it has a battery but would assume so. My question is can I actually code the thing myself or is that taking DIY too far?  :scared:
Offline JPW
Re: Keyfob query
« Reply #7 on: October 18, 2010, 11:14:33 pm »
GTiBeer - you have PM
Offline TonyZed
Re: Keyfob query
« Reply #8 on: October 18, 2010, 11:51:23 pm »
There are two different codes that need matching to your car.
One is for the remote for alarm and central locking, which you can do yourself, this is the one that the battery is needed for.
The other code is the immobiliser one, which is what the transponder holds. This doesn't need a battery, but needs coding with special equipment that the dealer has. Depending on the age of the car, some other people have gear that can do this.
Brief answer, but it's late :indifferent:
TonyZ
TonyZ
Offline GTiBEER
  • Golf Loving Mo Fo
Re: Keyfob query
« Reply #9 on: October 19, 2010, 10:58:13 am »
Thanks JPW I will give it a go tonight  although the post below makes it sound like i will only get 50% of the way there.
The dealer has told me it is half an hours work and will cost me £65. Would be nice to put that money towards the reconditioning of my alloys :)
Offline JPW
Re: Keyfob query
« Reply #10 on: October 19, 2010, 11:02:40 pm »
Let me know how you get on.
Offline GTiBEER
  • Golf Loving Mo Fo
Re: Keyfob query
« Reply #11 on: October 20, 2010, 12:50:44 am »
Tried it several times and the car would bit react I.e the horn would not beep.
My key is still in two pieces and font want to out them together unless I have to, would that matter?
Offline JPW
Re: Keyfob query
« Reply #12 on: October 20, 2010, 06:37:08 pm »
Have you tried both instructions.
Mine worked better for the Seat instructions, even though it's clearly a VW.
Offline AnilS
  • -Given: 50
Re: Keyfob query
« Reply #13 on: October 21, 2010, 04:57:43 pm »
Well, the dealer replaced the battery and coded it to the car, all for £3  :confused: :happy2:
Offline GTiBEER
  • Golf Loving Mo Fo
Re: Keyfob query
« Reply #14 on: October 22, 2010, 11:11:28 pm »
£65 later and I feel used after reading that last post :(
