Author Topic: ed 30/ se intercooler  (Read 2394 times)
Offline x18wag
« on: October 18, 2010, 12:21:50 pm »
sorry if i put this in the worng area, just wondering will i need a ed30/s3 intercooler to run my ko4 turbo? i recently bought a ko4 injectors and some pipe work, but someone mentioned that i might need a bigger cooler?
any help appreciated
andrew
blue graphite Gti, full leather, arm rest with 6disk changer, 18'' Monza 2's, now changed to Perscara's, rear (i cant see) parking sensors :p dual climate, pipercross panel filter. remus sports cat back to come
Offline S2 Ant
  • -Receive: 21
Re: ed 30/ se intercooler
« Reply #1 on: October 18, 2010, 03:12:31 pm »
I dont know this for certain but in terms of cooling, a standard item would obviously be ok, but not as efficient as the S3 / Ed30 coolers and so would limit what you could get from your K04 as the higher boost it can generate will need greater cooling.
Also, the pipework needed for the K04 might be different dimensions, altho as i believe you are able to relocate the DV on a K03 car using the necessary pipework then i suspect that fittings should all be fine and will just come down to cooling efficiency of the IC.
As i say, im merely guessing based on how the thing operates and am also in need of a definitive answer as i'm going from K03 to K04 as well soon.
Ant
Offline jhtrophy
  • Oh no it's a diesel
« Reply #2 on: October 18, 2010, 04:09:12 pm »
think the ed30 has same cooler as gti, s3 has the better one, i could be wrong though :signLOL:
Offline kevinm
  • -Receive: 25
  • No. 728
« Reply #3 on: October 18, 2010, 04:36:48 pm »
Ya you're right :happy2:
Offline x18wag
« Reply #4 on: October 18, 2010, 06:38:12 pm »
so i should not have a problem bolting on my k04 this weekend  :laugh:
Offline kevinm
  • -Receive: 25
  • No. 728
« Reply #5 on: October 18, 2010, 08:22:49 pm »
The gti intercooler is no where big enough for a KO4. My car suffers alot of heat soak.
As regards the KO4 conversion...will the car need to be mapped to the turbo or will the ecu adapt?
Offline x18wag
« Reply #6 on: October 19, 2010, 12:00:50 pm »
ye im in the middle of gettin a price for a revo, so looks like ill just sell my KO4 as cant be bothered buying more bits lol
