Author Topic: bennylenny88 needs your help!  (Read 15587 times)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: bennylenny88 needs your help!
« Reply #15 on: February 12, 2009, 11:55:45 pm »
But a simple bit of research would net that for you and you'd be better equipped to find the part.  Up to you, I'm only trying to help.
In the boot under the carpet should be a build sticker, it will have the 3 digit identifier for the gearbox.
Stu...
Offline cmdrfire
    • Commander Fire - my blog
« Reply #16 on: February 12, 2009, 11:59:48 pm »
1) Replace gearbox with new unit
2) LEARN HOW TO USE CLUTCH
3) ???
4) Profit!
Offline bennylenny88
  • needs moar lowwww
« Reply #17 on: February 13, 2009, 12:33:50 am »
i know you are im not being a dick here mate. but ive got a 6sp in atm and my stickers not there from when i had this box in the boot.. it ruined it
Offline cmdrfire
« Reply #18 on: February 13, 2009, 12:56:56 am »
  • needs moar lowwww
« Reply #19 on: February 13, 2009, 01:01:11 am »
right ive dug out my haynes manual and it says the gearbox code is
0AF
engine code is BCA and BUD if that helps too
thanks stu
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #20 on: February 13, 2009, 07:08:23 am »
Ok, lets try a different angle - PM me your chassis number.
Engine will be one of the two and not both - Unless you've put a sneaky one in the boot!!
Stu...
  • needs moar lowwww
« Reply #21 on: February 13, 2009, 11:18:04 am »
will do mate :) thanks a lot
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #22 on: February 13, 2009, 12:04:43 pm »
That's not the chassis number you sent.
Stu...
  • needs moar lowwww
« Reply #23 on: February 13, 2009, 12:53:45 pm »
i know its my plate.. im not at home atm..
Offline WhiteGTI
  • F-A-S-T
« Reply #24 on: February 13, 2009, 12:55:28 pm »
LOL! Sounds like your making things rather difficult Benny! Why are you going for a 5spd, when you have a 6spd in it currently?
2006 E46 BMW M3 - 343hp
  • needs moar lowwww
« Reply #25 on: February 13, 2009, 01:03:00 pm »
i know im trying not to be but i cant go home atm just doing something..
because when my first box broke we went scrappers to get another 5 sp.. luckly we ended up with a 6 speed.
but since ive no job atm im after the best offer i can get :\ so 5 speed i think.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #26 on: February 13, 2009, 01:16:25 pm »
Your Gearbox is a FXQ and the Engine is BCA
FXQ was fitted to -
Golf/Golf Plus from 10/03 to 11/06
Altea from 05/06 to 11/06
Leon from 06/06 to 11/06
Toledo from 05/06 to 11/06
Octavia from 05/04 to 11/06
The part number is 0AF 300 040 BX, you can also use the JHU which is 0AF 300 040 P
JHU was fitted to -
Golf from 11/06 onwards
Golf Plus from 07/07 to 10/07
Altea from 1/06 to 05/07
Leon from 11/06 to 05/09
Toledo from 11/06 to 05/07
Octavia from 11/06 to 05/09
That wasn't difficult was it.
Stu...
  • needs moar lowwww
« Reply #27 on: February 13, 2009, 01:17:41 pm »
oh right well dealer said SXQ... must be my hearing :(
sorry stu.
whats the best you can do for me?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #28 on: February 13, 2009, 01:30:48 pm »
I've done it, it's above!!
You could try http://www.skospares.com/contactinfo.htm
Stu...
  • needs moar lowwww
« Reply #29 on: February 13, 2009, 01:40:42 pm »
ohh right!! thoguht you worked at a dealers or something hahaha!!
im sooo sorry stu thanks for being patient
chinese blondeeee
