Author Topic: bulbs  (Read 2185 times)
Offline gti265
bulbs
« on: October 19, 2010, 10:22:32 pm »
hello all i have xenons normal driving lights, but my full beams and side lights look pants when on with them,
i belive the bulb i need is h1 for full beam and 501 for the side light, is that correct??
and also where can i get some nice bright bulbs from,
sorta blue (matching the xenons for the side lights)
and as bright as possible for the full beams
also car is a 56 plate gti 2007 (if this helps)
thanks
tom
MK6 Golf R DSG 2012 - FOR SALE - £20,000 - pm for info
Offline gti265
Re: bulbs
« Reply #1 on: October 20, 2010, 11:03:27 pm »
can anyone help??
Offline keith
Re: bulbs
« Reply #2 on: October 21, 2010, 11:07:05 am »
check out        http://www.powerbulbs.com/
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: bulbs
« Reply #3 on: October 21, 2010, 11:53:22 am »
The xenons on the MK5 are bi-xenon so the diaphram should open up for full beam giving massive clear light.  I also think you can turn off the standard bulbs and only use them for flash function.  Side light bulbs you can get LED's that will match the colour of the xenon bulb just make sure they have an in-line resistor so they dont throw up a blown bulb warning.
Offline Lee01
Re: bulbs
« Reply #4 on: October 21, 2010, 12:16:22 pm »
If you are after a standard bulb, however better quality check out PIAA.
Offline MattPoss
Re: bulbs
« Reply #5 on: October 21, 2010, 08:40:04 pm »
I've PM'd you regarding the sidelights :happy2:
Matt
Offline gti265
Re: bulbs
« Reply #6 on: October 22, 2010, 12:06:26 pm »
i thought bi-xenons where only fitted to r32 as standard?? as mine are definatly just xenons main beam, and full beam is a difrent bulb and a yellowy light?
thanks
tom
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: bulbs
« Reply #7 on: October 22, 2010, 12:14:41 pm »
no if coded properly you should get both the halogen bulb and the xenon diaphram opening up for main beam, the standard setting also just uses the halogen for daytime flashing rather than turning on the xenon bulb.  are yours standard equipment or a retrofit?
Offline gti265
Re: bulbs
« Reply #8 on: October 22, 2010, 12:23:20 pm »
no idea, i brought the car second hand, but there is alot of equipment that has been fitted aftermarket but using vw parts
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: bulbs
« Reply #9 on: October 22, 2010, 12:43:42 pm »
Having just had a look at the kufatec website (and assuming they were retor fitted) then it might be they werent installed with bi-xenon capability.  Do you have auto levellers for them and headlight washing? might be worth checking your PR codes to see what equipment was original factory fit as that will help to narrow down if they were retro fitted.
Offline gti265
Re: bulbs
« Reply #10 on: October 22, 2010, 12:51:05 pm »
yep they are auto levaling, and i have head lamp washer system :), ok i shall have a look later :) and see what it came with as standard :)
Offline gti265
Re: bulbs
« Reply #11 on: October 22, 2010, 12:58:11 pm »
also power bulbs say the bulb i need for full beam is H7, halfords said it was H1, which one do i belive??
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: bulbs
« Reply #12 on: October 22, 2010, 01:50:22 pm »
was just on the awesome site and they seem to be listing H7 in there MK5 section.  Having used to work at Halfords (11 years ago) I wouldnt trust what half of them say!  :grin:
Offline simonp
  • -Receive: 38
  • No longer a Golfer
Re: bulbs
« Reply #13 on: October 22, 2010, 01:57:27 pm »
PIAA are overpriced rubbish. Poor geometry, poor life and poor output.
Offline gti265
Re: bulbs
« Reply #14 on: October 22, 2010, 02:09:21 pm »
il go with what powerbulbs say then :)
