Author Topic: Parrot mulican installation?  (Read 1141 times)
Offline dan_gt
« on: October 19, 2010, 10:25:24 pm »
I am looking into buying a parrot multican (allows mfsw control) has anyone fitted one? Are they straight forward or do they require an expert to install?
Dan
Offline Garth
    • My Build thread
Re: Parrot mulican installation?
« Reply #1 on: October 19, 2010, 10:39:22 pm »
Dan
I fitted one a while back to my car. It was really simple to fit. Follow the instructions and you can't go far wrong. The only bit you might not realise is that if you're going from having the parrot handsfree kit already, you will need to disconnect the switched live on the parrot kit. The kit will receive the switch on signal from the multican. If you leave the switched live it will not work.
If it's a new install then just don't connect the switched live of the handsree kit  :happy2:
Offline mortygttdi
  • -Receive: 146
« Reply #2 on: October 20, 2010, 01:42:45 am »
Dan if you have the ck3000 i have the multican in the loft gathering dust, you can have it for £15 delivered,
Darren
