Author Topic: The big switch over. APR to REVO  (Read 30491 times)
Offline wigit
  • -Given: 129
  • -Receive: 42
Re: The big switch over. APR to REVO
« Reply #45 on: October 22, 2010, 12:54:31 pm »
not going to get too drawn into numbers on the revo tsi stage 2 as i'm going to be running that file for a few weeks, after a 50 mile drive i am happy with the performance on the road, the car has more torque steer in 3rd (so feels a bit more like the Pirelli Stage 1), fortunatley my rocco is running an upgraded clutch  :wink:
Offline four!
« Reply #46 on: October 22, 2010, 04:21:33 pm »
Did anyone get them to plot the AFR and boost on the comparison runs?? It's always handy
That way you can get an idea of where the extra came from, either boost, fuel or ignition or a combination of any of them in the right places.
Offline Pablos007
« Reply #47 on: October 22, 2010, 04:25:06 pm »
Not quite lol
Final result is 271bhp and 332lbft which I think is not bad for an engine with 100k on it. Will post the graph later this evening :happy2:
How does it feel to drive in comparison?
Offline ukdub
« Reply #48 on: October 22, 2010, 05:09:07 pm »
Not quite lol
To be honest, it feels just as smooth as the APR map in delivery, just more power everywhere and in every gear. To me, the most impressive thing is how the car feels in low boost and off boost town driving. It just feels so much more responsive without being too aggressive.
Final settings used was,
Boost 9 timing 6 fuel 9
Funny thing was we had more timing pull on the first run on the 'safe' settings which were
Boost 7 timing 4 fuel 9
Next it was 8, 4, 9 which made more power and torque, then we tried 8, 4, 8 which lost power and gained a little torque. So back to 8, 4, 9 which put the power back. Next run we increased the timing to 5 and the logs showed 0 timing pull. Next run timing to 6, again more power and torque. Mark and John said "right let's leave it there" to which I replied let's have a run with boost at 9 to see if things look fine. They did and I got my final figures  :laugh: :happy2:
Laser Blue with K04 power, APR hardware controlled by REVO 2+ software
Chassis by KW V3's, Whiteline and a hint of PRO race 1.2's
Brakes by Brembo 4 pots
Offline four!
« Reply #49 on: October 22, 2010, 05:51:03 pm »
Pretty impressive from just a change of software. Makes you wonder if more was available from a few tweaks of the other software.
I take it the 3 number settings you mention modify the ignition curve, fuel map and boost target across the entire rpm/ load range by a set amount? Is there no provision to modify certain areas of the map leaving others untouched?
Just interested really, not familliar with how it works on vw stuff.
Anyway bet you're well pleased with that gain without any other mods.
« Last Edit: October 22, 2010, 06:05:54 pm by four! »
Offline Arin@APR
« Reply #50 on: October 22, 2010, 06:12:09 pm »
Jim said to me "I can't believe we have being lied to all this time"
This is a troubling statement to read for several reasons. AWESOME GTI is well informed of our tuning philosophy and seemingly felt the same. AWESOME GTI also did not suddenly pick up a dyno over night. They've had one for quite some time now and had every ability to check the power gains of our software in house any time they pleased. They were present on our calibration trips to their own shop to tune European cars in years past. They were right there in front of us, looking at the exact same data as everyone else. They've had dyno day shootouts and many customers from all makes of cars and all mods on their dyno for years now so tuning philosophies differences have been clear for years.
id like to hear what APR's thoughts are on this!  :signLOL:
Below is what I wrote on another thread. I've removed a few things to make this more in response to this thread.
First, I'd like to touch on APR's Conservatism/Aggressiveness at different stages with regard to how hard the turbo is run
In the case of stage 1 and stage 2 software, we are a bit more conservative compared to our on upgraded turbo software. But in all cases we do not cross the manufacturers specified levels for exhaust gas temperature. Another area where we don't run 'wide open (or shut rather)' is with the wastegate. With stage 3 software and our k04 software, we leave some headroom so the turbo can make up for differences in altitude changes and for small boost leaks and several other reasons. It also leaves some headroom for minor differences which inherently exist in all things in nature. When calibrated in house at APR we are not running wastegate duty cycle at 100% during an entire pull. 100% wastegate duty cycle means the wastegate is fully shut and all exhaust gasses are going through the turbo running it as hard as possible. For the MK6 typically with stage 1 and stage 2 you'll see less duty cycle towards redline. With our k04 and stage 3 setups (depending on engine size and turbo size) you may see a more aggressive approach where more of the turbo is utilized. This depends on many different variables, but for the most part, OEM turbo software will be less aggressive.
When running a larger turbo such as Stage 3, running it harder has a higher percentage gain than smaller turbos such as the OEM. With an OEM turbo, running harder will in some cases get more power, however the percentage gain is much smaller. This is another reason why we typically leave more on the table since running it harder doesn't make a tremendous difference. There are trade offs to running it higher and harder and our engineers chose not to do so.
Lastly, especially with stage 1 we like to make power but we like to keep things on the safe side. Most customers want it this way. Also, being under warranty, we don't feel it's fair to VW if we were to just run the turbo as hard as possible, risk failure, and then pass the bill off on them. That in our opinion is dishonest and that's not what we want to do. (Please keep in mind, I'm not insinuating other tuners do this, I'm simply stating another reason why we don't run the turbo at 100% on the mk6)
Secondly, I'd like to touch on APR's Conservatism/Aggressiveness at different stages with regard to component protection.
Each and every APR stage, from stage 1, to stage 4, has component protection enabled. What this means is as EGT's rise, we will run less aggressive fueling maps which will run richer in order to cool the exhaust gasses. For those who do not know, in many cases, running richer will result in a slight power loss, however, the fuel will actually cool down the exhaust gasses and will prevent EGT's from crossing the manufacturers limits.
You can see this on the dyno and it's even possible to see this on the road.
If you were to log air fuel ratio and do pull after pull after pull on the dyno or on the road, you'll see after a while (especially on the dyno where there is VERY limited air flow), the air fuel ratio will become richer. This is 'component' protection. The lower limit, or richer air fuel ratio can be adjusted by the tuner. It can be set to the exact same level as the 'performance' map too, thus when it comes time to cool the exhaust gasses by switching to the other map, the other map will be the same and the air fuel ratio will not change.
Not all tuners disable this feature, I'd like to make that clear, but this is an excellent reason why 1 guy with APR software can put down 1 power figure, and then you can go to the same dyno and put down less. If there is less airflow over the engine or if your car is hotter, it can switch to a mode where it's protecting the engine from harm. You'll put down less power but there will be nothing wrong with your car. Remember, cars drive ON THE ROAD, not on the dyno. There is far more air rushing throughout the engine bay, intercooler, radiators, etc cooling it down when it's on the road compared to the dyno. With these protection routines in place, it makes is possible to run the car in brutal conditions w/o harming the engine or turbo.
Stage 1 with the OEM exhaust will be the most affected power wise from component protection. It's less aggressive and will be safer. This is larger in part due to the restrictive exhaust right next to the turbocharger. It gets hot quickly! So once you remove this restriction and go to stage 2, the restriction is gone and it does not get quite as hot as quickly. This is why we can run more 'aggressively' while actually not running any hotter. It's actually less aggressive in a sense since the restriction is removed.
Third, I'd like to touch on the power difference between the APR and Revo files in these dynos
I personally do not have data in front of me other than 1 dyno graph of 1 pull with Revo map vs some APR file.
Now, looking at the two graphs, it's clear in these two dyno plots the REVO pull is making more power. This is clear as day and anyone can see it.
Could this data be faked? Absolutely.
Do I personally believe it's faked? I personally do not believe it was 'Faked'.
Could it be slightly dishonest? Absolutely.
Do I think it was slightly dishonest? Not really, but maybe just a little to make things look a bit more 'dramatic' but hopefully nothing major.
Let me touch on that:
There are several things which could have happened to make it "dishonest". Let me again say I don't think it truly is 100% dishonest or fake, but I would like to mention a few things which can make a delta appear much larger.
1. Above I mentioned component protection. One way of making less power would be to run the car over and over and over. Typically if there is not enough air flow over the vehicle, such as on the dyno, our calibration will do everything it's capable of doing to run richer, pull timing, and even pull load/boost to make less power and run safely. I don't believe they beat the crap out of the APR tune to get it to read very very low in order to sway the results. Could they have chosen the worse run for the APR data? Yes, that's always possible, but the power figures they are reporting seem to be very good to me and more or less what we advertise. I don't think they went out of their way to make the APR data look bad, but they may not have chosen the 'best' run.
2. Did they choose the best Revo run vs the worst APR run? Could have but I have no way to prove this.
3. Could this be a custom 1 off file from Revo just for this test? Yes, it could be, but I have no data to prove it.
So as you could see, it could or could not be the best run vs the worst run just to make the delta larger, but we have no data to support that claim, nor do I think it really is. I don't doubt they have the ability to make a lot of power no the OEM turbo. I know we have the ability to produce much more power on the OEM turbo compared to what we feel is safe to sell to our customers. I don't doubt at this point REVO has the same ability to produce high levels of power from the OEM turbo as well. As far as the OEM turbo goes, pulling out higher power levels is the easy part.
Conclusion
I've said it before, any tuner can run the turbo harder than anyone else out there and extract more power and we have the same ability to do this as well. This is the easy part! We have sold our software to thousands upon thousands of customers around the world and our customers are happy. We offer what we feel our customers want and are not exaggerating power gains. We offer a product line of hardware and software to support power gains from mild to wild while keeping a thick powerband of steerable and trackable power and our customers seem to love it. We calibrate the components to a level we feel is SAFE, not to the max, and not to beat other tuners.
Through motorsport racing we have stretched these engines to the limits with OEM components and put them through abuse people will not see on the road with our stage 1 or 2 software. In racing the MK6 we are limited on the boost we can run and as such have to dig else where to extract more power safely. The midrange will sacrifice but towards redline, we are pushing it to the max. We've destroyed turbos with racing. A full weekend of wide open hour long sessions of running it at the max will do that! We replace turbos after races because they can't continue to see the levels abuse we put them through over and over. This data has trickled down into our sellable performance software and since 2008 when it was first released, has proven over and over it's safe for the road and track.
We know the limits, we don't cross them for our street customers. We provide smooth and drivable power gains we feel are safe for both you, and your engine.
Thank you!
-Arin
« Last Edit: October 22, 2010, 06:15:06 pm by Arin@APR »
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #51 on: October 22, 2010, 06:29:06 pm »
Makes perfect sense to me what Arin has wrote.
Its like when people approached GIAC to make a file to compete with revo for the quarter mile. They did so easy peasy and made huge bhp numbers. But then we all know that revo is generally the most aggressive, however if a revo customer wants it a little more mild all you have to do is adjust the settings via the sps, so its a best of both worlds!
Offline Janner_Sy
  • -Receive: 113
« Reply #52 on: October 22, 2010, 06:32:32 pm »
thansk fior the reply.  Id agree with that as well.
i was always under the impression that the APR k04 map was slightly lower than it could have been to leave a larger gap between the k04 and GT28 as they are so similar in performance. m Lets be fair if the K04 was really close, why would someone swap to the GT28 for all that extra dollar for not a lot of extra power
Many guys on here have had run ins with the ko4 Vs GT28 and al have said that whilst on track it might be faster, it isnt in the real world
« Last Edit: October 22, 2010, 06:38:20 pm by Janner_Sy »
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #53 on: October 22, 2010, 06:33:32 pm »
Thanks for the Reply Arin  :happy2:
Offline Arin@APR
« Reply #54 on: October 22, 2010, 06:53:07 pm »
With the K04 to get more power of it you have to run it near 100% towards redline. I actually was a customer at the time of K04 development and donated my car to APR for development of this kit. At the time an EGT Probe was installed in the turbo to collect both EGT data on the dyno and on the road. By pushing the turbo much harder, it was getting pretty hot and was beyond what we felt was safe for both normal use and especially track use. The last thing we want is someone to purchase this kit and burn it up the first weekend they take it out to the track. (just to clarify, I'm talking about real track, not a drag strip) So power was not limited for the sake of stage 3, it was limited because at the time we did not feel it was safe to push it harder as it was crossing the manufacturers specified limits for exhaust gas temperature.
With everything out there, there's always room to make a little more power. Is it safe? We don't think it is, but these are your cars. You can choose whatever you want.  :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #55 on: October 22, 2010, 06:55:22 pm »
Who is the main Uk APR dealer now then?  and will there be any changes in the software to make it more competitive with revo, who seem to be running the monopoly on the TFSI now
Offline ukdub
« Reply #56 on: October 22, 2010, 07:08:58 pm »
Arin. I don't have a problem with APR software or their tuning philosophy. The main problem I had was that my preferred tuning house (awesome) no longer would be suppling your product. I have run problem free on this car with APR software for over 80k. I am still not saying Revo are better than APR, just that I am now making slightly more power and feels more responsive in a low/off boost situation all with safe logs according to VCD.
Oh, and we only did one run on your software.
Offline Janner_Sy
  • -Receive: 113
« Reply #57 on: October 22, 2010, 07:11:38 pm »
the key thing to note is not the figures but the fact that you can feel the positive difference between the two maps.  thats something that they cant make up.
We need to get these cars ran on an independent dyno now i think
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #58 on: October 22, 2010, 07:30:46 pm »
Very nice of you to stop by and even the playing field a little.  Thanks.
I also admire you for taking a fairly neutral stance and not having a poke at the opposition.   :happy2:
Stu...
Offline BenR
« Reply #59 on: October 22, 2010, 07:35:36 pm »
I 100% agree with this, I have run more or less problem free on APR since last christmas on stage 1, then for the past month on 2+...loved every drive in it, but the fact that my closest APR dealer is now a good few hours drive away I thought it best to change over to Revo at Awesome as they are only a 45minute drive away.
The only problem i had with the APR stage 1 was that in 5th/6th gear at 130-140mph it would almost missfire and you could feel the power drop on and off, was told this was normal and a common problem on stage 1.
Again only 1 run was done on the APR with mine too....as Ash said earlier mine got 358bhp and 410lb/ft torque....can feel the difference in the two maps but as said before in this thread its not all about the figures its about where the power is in each gear and I can honestly say thay the Revo is on power a lot more than the APR was, the only way I can explain this is to say that the APR felt almost 'laggy' in comparison?
Will have more to report after the weekend after a good drive of the car!
