Author Topic: DEFI Blue Racer 52 mm Boost Gauge / OPOD Mono OSIR pod inc fitting  (Read 54518 times)
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
Re: DEFI Blue Racer 52 mm Boost Gauge / OPOD Mono OSIR pod inc fitting
« Reply #15 on: February 14, 2009, 10:50:31 am »
cmdrfire : the gauges are imported anyway so I reckon you could get the metric variant just as easily.
TC : appreciate the comments. you must have taken your nice pills today  :P
Red ED35 5dr DSG
BLOG | BUILD
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #16 on: May 06, 2009, 08:58:14 pm »
edited to add wiring pic  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline SteveS
« Reply #17 on: May 06, 2009, 09:08:12 pm »
very helpful!
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline Mark_GTIV
« Reply #18 on: May 16, 2009, 08:51:50 am »
I had Defi meters fitted to my Subaru WRX with the control box fitted, so you could play back your run, you could read peaks, set audible and visual warnings etc... they were excellent.
As you can see they do support metric versions of the clocks. I had exhaust temp (i had the probe in my downpipe), oil temp and boost. I notice that you can get an enclosure that replaces the air vent on the top of the dash, with something like I had for the WRX.
The whole kit is a little expensive, but if you've made some bigger modifications - these are a must.
I had the control unit discretely mounted under the steering wheel.
« Last Edit: May 16, 2009, 08:54:36 am by Mark_GTIV »
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #19 on: November 13, 2009, 10:36:20 pm »
Had my DEFI gauge fitted today...generally pleased with it. Shame that the blue back light doesn't exactly match the OEM blue.
Did anyone figure out how to get the dimming function to work without cutting any wires?  Apparently, I need to find a 12V feed from the lighting circuit?  For the moment, its set to full illumination which is a bit too bright during the night....
P.S. My gauge peaks at around 21psi... can anyone explain what the inHg and psi values mean?
« Last Edit: November 13, 2009, 10:42:01 pm by xxx_mojo_xxx »
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #20 on: November 14, 2009, 10:56:38 pm »
i have run mine as 'night dimmed' from day1  :happy2:
never got any further on tapping into the dimmer feed as I dont like it any brighter (even during the day)
inHg - inches mercury for vacuum
psi - poundsPerSquareInch for positive pressure
Red ED35 5dr DSG
BLOG | BUILD
Offline cmdrfire
    • Commander Fire - my blog
« Reply #21 on: November 14, 2009, 11:39:41 pm »
Men use BAR.
  • MUBster DUBster
« Reply #22 on: November 15, 2009, 09:23:41 am »
Thanks, John_o.  So what how does vacuum vs positive pressure affect boost?
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #23 on: November 15, 2009, 11:01:41 pm »
thats a whole bigger subject but positive pressure IS boost
(i.e. you can cram more air using the exhaust driven turbocharger , and therefore more fuel into the engine = bigger bang = more power)
vacuum is the opposite condition usually when your foot is off the throttle and the pressure is negative.
only a forced induction car will show a positive large 'boost' value, but both a forced induction car and a normally aspirated will show vacuum values
my very simple 2p  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
  • MUBster DUBster
« Reply #24 on: November 15, 2009, 11:13:39 pm »
So, why doesn't my boost shoot into the PSI section of the gauge everything I press the peddle.
I always get movement in the gauge needle...but some times I can be ragging it and the dial simply moves in the lower part of the gauge, i.e. the 0-30 inHg.
Other times,  the needle moves straight into the 0-30 psi bit...
Or is there something wrong?
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #25 on: November 16, 2009, 07:52:36 am »
there are some conditions where youll be in an inbetween 'phase'
(+ = psi/boost , - = mmHg/vacuum)
cruising at 85mph mine sits at -10 (i.e. its a part throttle)
general driving on light throttle I'm barely ever in +ve side
if you are on full or medium throttle you should be registering some + boost from any rpm.
going down a slip road under light throttle in 4th/5th I can make good progress and the guage registers around 5 psi
you cannot achieve large boost values at very low rpm (as the exhaust gases arent making the turbo spin fast enough)
if you were 'ragging' it , then I would always expect you to either be WOT(boost) or lift off (vacuum) , so yes you should see some boost all the time.
BUT if you go WOT in 6th gear from low rpm dont expect huge psi values.
below 2000rpm expect 3-5 psi then it should build quickly to peak around 2700 rpm (depended on the turbo you have)
as an experiment , try a straight empty road , be safe!, 3rd gear 50mph (what rpm is this)? and try going on and off the throttle to WOT , the guage should immediately go into the +ve side each and every time without fail, then back into -ve when you lift off
if it doesnt then yes you have a problem.
have you fitted an forge DV ?
do you have access to someone with VCDS who can log the car ?
let us know how you get on
Red ED35 5dr DSG
BLOG | BUILD
  • MUBster DUBster
« Reply #26 on: November 16, 2009, 11:11:27 am »
Thanks John_o - from your description the boost gauge/turbo appears to be working as expected.
Got a Forge DV valve.
No access to VCDS - is there anyone nearby?
And, what is WOT short for?
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #27 on: November 16, 2009, 11:35:20 am »
check out the VCDS section where theres a list
WideOpenThrottle  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
  • MUBster DUBster
« Reply #28 on: November 16, 2009, 10:04:51 pm »
Cheerz!
Offline BLUE-STORM
  • GOLF GTI VS CLIO 172 SPORT
« Reply #29 on: February 23, 2012, 04:33:03 pm »
hey people  dose any one know where i can get hold of one of these gauges and the pod to hold it in the vent , for the gti mk5 ,    cant seen to see any link to buy them , could some ojne give me a link , thanks chris
