Author Topic: Erratic idle  (Read 17335 times)
Offline sixpot
Erratic idle
« on: February 12, 2009, 07:44:04 pm »
I have noticed the revs hunting when idling recently, the car also seems jerky when coming off the gas at part throttle, do you think there is something amiss?
Offline billyboy
  • Billy lar
Re: Erratic idle
« Reply #1 on: February 12, 2009, 07:53:32 pm »
summits not right there lar,
hope ya get it sorted lee, keep us posted
bill
Offline tony_danza
  • -Receive: 112
Re: Erratic idle
« Reply #2 on: February 12, 2009, 08:51:56 pm »
Could be the MAF on its way out? pull the plug to it and see if it runs any different?
Sideways yo!
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
Re: Erratic idle
« Reply #3 on: February 12, 2009, 08:55:57 pm »
worth a check for air leaks etc.
However mine does 'hunt' occasionally and the effect is made worse by what I believe to be cr*p engine mounts with too much play!
Did it do it before? If not then somethings changed of course
Red ED35 5dr DSG
BLOG | BUILD
Offline sixpot
Re: Erratic idle
« Reply #4 on: February 13, 2009, 07:10:54 am »
My first initial thoughts were maybe the throttle body needs aligning, which is easy enough to sort with a battery disconnection.
I may also take the MAF off and clean the element with some carb cleaner, and I'll also check the diverter valve for any obvious rips/tears etc. Other things I've considered are a faulty lambda sensor (but surely this would illuminate a dash light?)
Are the MAF's still prone to fail like the older VAG ones?
Either way I think I'll get a code scan done and see if anything is thrown up.
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Erratic idle
« Reply #5 on: February 13, 2009, 07:14:55 am »
nooooooooooooooo - Don't clean the MAF.  Bite the bullet and order a new one if you think that is the problem.  It's not so much about being prone to fail like the old ones but the fact that it should really be a service item,  it monitors every bit of air coming into your car so it's pretty much in the firing line all it's life.
Stu...
Offline 182_blue
  • -Receive: 54
Re: Erratic idle
« Reply #6 on: February 13, 2009, 08:01:27 am »
Have you vag com'd it, someone may be able to help, what area you in
Offline sixpot
Re: Erratic idle
« Reply #7 on: February 13, 2009, 11:17:17 am »
I don't have VAG COM myself. I'm in Warrington, Cheshire.
Offline CocoPops
    • Kennet Heath
Re: Erratic idle
« Reply #8 on: February 13, 2009, 02:13:10 pm »
I'm in Chester next week with work, so will bring my vagcom cable with me.
PM me next monday.
Used to Own: 2008 GTI Ed30 | ITG Intake | Miltek TBE System | Bluefin Stage 2 | 327bhp
On Order: 2017 Golf GTI Performance Pack 5dr DSG
Also own: 2016 Lotus Evora 400
Offline Norbreck21a
Re: Erratic idle
« Reply #9 on: February 13, 2009, 10:39:51 pm »
Sixpot,
I work in Warrington, If you can pop down one luchtime, I'll happily do a scan for you ?
let me know.
Andrew
Offline sixpot
Re: Erratic idle
« Reply #10 on: February 14, 2009, 09:04:02 am »
Sixpot,
let me know.
Andrew
That would be great, as I'm working late shift next week, so I could do that at lunchtime.
I'll fire a PM over.
Lee
Offline Norbreck21a
Re: Erratic idle
« Reply #11 on: February 15, 2009, 12:17:05 am »
No sweat sixpot, I work in Birchwood just off the junction for the M62. I'm not in the office until Wednesday, but any time from then onwards suits me. Send me a PM as you said and I will give you my details.
PS if you have one, bring a memory stick with you so that the scan can be saved onto it for your records.
Offline sixpot
Re: Erratic idle
« Reply #12 on: February 15, 2009, 08:31:48 am »
OK, that suits me fine. Cheers.
Offline billyboy
  • Billy lar
Re: Erratic idle
« Reply #13 on: February 15, 2009, 09:02:35 am »
WOW lee
great, carnt get fairer than that,
lets know wots been found.
bill
Offline sixpot
Re: Erratic idle
« Reply #14 on: February 15, 2009, 07:50:32 pm »
WOW lee
bill
I did a throttle body alignment today, so we'll see how she runs tomorrow. Yep thats the beauty of forums, there is always someone willing to help you out. I will keep everyone informed of the outcome. Cheers.
